Hi Aaron,
We do not use the picklist here because we make design and build everything
to order and nearly all the components are also designed and manufactured to
order. However, as far as I know, you are able to control who can print the
picklist by the using the same security methodology that applies to the rest
of the system. If you wanted, you could go into the security for
that report and give only one person access to printing it, or as many or as
few people as you want either by security group or by user name.
As far as people being able to modify the picklist, that would depend on
where the information comes from. You would first have to determine where
the information on the picklist comes from and then limit security to those
modules.
Sarah
modules.
Sarah
