A collegue ran the conversion process to upgrade to 9.05.604 and received the
following message (multiple times):
Error Detail
Â
Control ‘epiComboC38’ of type EpiCombo has an invalid binding to
PartClass.ShortChar48
Â
Stack Trace
Â
At Epicor.Mfg.UI.FrameWork.EpiControlHelper.ColumnExists( Object ownerControl,
EpiDataView
  epiDataView, String columnName, Boolean throwException )
Â
at Epicor.Mfg.UI.FrameWork.EpiUltraCombo.EventSetup(Â ) at
Epicor.Mfg.UI.FrameWork.EpiUltraCombo.set_EpiTransaction(Â IEpiTransaction
value ) at Epicor.Mfg.UI.FrameWork.EpiUIUtils.BindNConfigureControls( )
Â
Does anyone have any thoughts? I believe this may be in relation to a problem
with the conversion for an Extended UD table. Are there any known issues with
the conversion and Extended UD tables?
Â
Gene McDonald
Illinois
Error Detail
Â
Â
Stack Trace
Â
EpiDataView
Â
Â
Â
Gene McDonald
Illinois
