I don't know what it is, but it is working now. It would not work with test database loaded. I restored production database and went through my steps like normal as it started working again. Don't figure. Well if I have anymore trouble I will let you know. Thanks.
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> There are lots of things that can cause this problem.
> What do the broker and agents logs of the AppServer say?
> Do you try and start it while you also have 8.00 running?
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> randyduly
> Sent: Sunday, October 17, 2010 3:52 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Conversion from 6.1 to 8.03.4xx
> We were upgrading our test server that we are using to do the conversion
> from 6.10.541 to 8.03.409C. We made changes to our RAID and added more
> drives and RAID-0. So that meant we had to reload all of our software again.
> The installation of Vantage 6.1.541, 8.00.705, and 8.03.409C went well. The
> only problem I ran into was the starting of 8.00.705 AppsServers. I believe
> I ran into this same problem when I first originally installed Vantage
> 8.00.705.
> What is happening, is I start up the database. Then start up the first
> appserver, which is mfgsys80. The mfgsys80taskagent and
> mfgsys80processserver starts just fine. The mfgsys80 appserver just keep
> saying "starting" and if you check the status of it, it say something like,
> "Still starting, try again later". Eventually after many minutes it will
> change to "Not Running".
> I won't swear to this but I think it was because the port numbers were
> wrong.
> Has anybody else ran into this? If not, I will call support. Thanks.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
