Conversion from V8 to E9.05.700 BAQ's
Not Legally ;-)
You could write a BPM that changes all the values. But not sure Epicor
would like that too much/.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Mon, Nov 12, 2012 at 11:04 AM, carol.pelowski <cmpelows@...>wrote:
> Is there a way to do this in one step, or will I need to go into each BAQ
> individually?
> --- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> > To re-import them all at once you have to use the Solution Manager, in
> > terms of changing the author you have to move them all to the same
> account.
> > Usually manager
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Mon, Nov 12, 2012 at 10:47 AM, carol.pelowski <cmpelows@...>wrote:
> > > We are going to be upgrading from V8 to E9.05.700. Many of our BAQ's
> > > required changes as a result of the TranGLC table which we took care
> of in
> > > a test conversion. We then exported the BAQ's and last week did another
> > > test conversion. Before we import the BAQ's we have to change each one
> to
> > > our name as author or it will not allow the overwrite. Has anyone
> found a
> > > work around for this? Or even a way to import them all at once?
> > > Thanks in advance.
> > > Carol
We are going to be upgrading from V8 to E9.05.700. Many of our BAQ's required changes as a result of the TranGLC table which we took care of in a test conversion. We then exported the BAQ's and last week did another test conversion. Before we import the BAQ's we have to change each one to our name as author or it will not allow the overwrite. Has anyone found a work around for this? Or even a way to import them all at once?
Thanks in advance.
Carol
terms of changing the author you have to move them all to the same account.
Usually manager
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks in advance.
> Carol
Is there a way to do this in one step, or will I need to go into each BAQ individually?
> Usually manager
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks in advance.
> > Carol
