Hello, I have a challenging task of converting strings into executable expressions.
string MyCalc = “100+200”;
decimal result = HopefulNamespace.ExecuteExpression(MyCalc);
As you can see, I’m hopeful for something in the library that has a method that converts strings into executable expressions. Has anyone been down this road before? How would you attack this? I could create a method of my own, but it seems to me like it would make sense that something already exists.
Might I ask where this string is coming from, and why it’s not being stored as its preferred data types? I’d think even if it’s coming from an external application, we might be able to parse it out prior to storing it as a string.
I appreciate all the feedback!!! I found, and was able to get the DataTable.Compute method working for me shortly after posting. Using:
System.Text
System.Linq.Expressions
I was able to convert strings into usable expression results in Epicor. The challenge will be “cleaning” and manipulating the strings that will be entered in. It will have to be quite rigid as far as user-entry. String-Fun coming my way! ← not sarcastic, I enjoy this stuff
In its most simplistic/experimental form (to help those in the future):
That’s intriguing: “stored as preferred data types” and I think that’s something I will look into. Thank you for the input. I just thought it simpler to convert the calculation into a string and then chop it up before pushing it through as a calculation. The problem is, the calculation entry screen will have things like MyVariable1+MyVariable2. When the calculation is used elsewhere, I’m going to have to use MyVariable# and replace the variable-name with the actual number entered in, and then compute them.
