Convert Configurator from 8 to 9 - DMT or?
I will investigate, may be easier than trying to rebuild them.
Thanks.
Scott
Stephen Edginton
Sent: Monday, November 12, 2012 11:29 AM
Subject: RE: [Vantage] Convert Configurator from 8 to 9 - DMT or ?
It is not really possible to convert these with DMT however you can create
the required methods in DMT for them..
You could then upgrade the V8 environment to version 9.05 and export them
from this and reimport them into a new 9 environment (as 9.05 you can import
//export configurators - but not methods)
Behalf Of Jose Gomez
Sent: 12 November 2012 16:15
To: Vantage
Subject: Re: [Vantage] Convert Configurator from 8 to 9 - DMT or ?
If they are EXTREMELY simply configurations they may convert... But if they
were extremely simple you wouldn't mind re doing them :(
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@... <mailto:jose%40josecgomez.com>
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Mon, Nov 12, 2012 at 11:04 AM, litzer1 <scott.litzau@...
<mailto:scott.litzau%40olympusgrp.com> >wrote:
> Has anyone been able to convert Product Configurators from Vantage
> 8.03.409 to E9 using either the DMT (which I see no option) or by some
> other means. I really do not want to have to re-create these.
> Thanks,
> Scott
Has anyone been able to convert Product Configurators from Vantage 8.03.409 to E9 using either the DMT (which I see no option) or by some other means. I really do not want to have to re-create these.
Scott
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Scott
It is not really possible to convert these with DMT however you can create the required methods in DMT for them..
You could then upgrade the V8 environment to version 9.05 and export them from this and reimport them into a new 9 environment (as 9.05 you can import //export configurators - but not methods)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
To: Vantage
If they are EXTREMELY simply configurations they may convert... But if they were extremely simple you wouldn't mind re doing them :(
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Scott
Unfortunately they are not simple, a lot of fields and rules.
Not converting directly, using DMT.
Scott
Jose Gomez
Sent: Monday, November 12, 2012 10:15 AM
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Scott
