Converting a Part to a different UOM
Good morning!
I’m new to Epicor Kinetic and could use a little help with the proper procedure to convert a part that was initially entered in the system with a UOM of EA when it should have been entered as LBS.
Doe anyone have a procedure on how to complete a UOM conversion from EA to LBS when there have already been transactions done on the part?
Any help would be much appreciated!
Thanks, Mark
Hi @markb333,
I’m assuming the ‘Part UOM Conversion’ doesn’t work for you? I thought that worked provided you don’t have stock on hand against the part, but I could be wrong?
if the part has any kind of transaction history your only option is to create a new part.
DeletingStuff
I tried this first, but it appears that since EA in a different UOM class than LBS it won’t let me do a conversion from EA to LBS for this part.
Mark
