Convmap.cp error
Take a look at the following.....
PROBLEM: Opening custom report links in Vantage generates the error: Unable
to open convmap.
XA500
XA510
XA520
RESOLUTION: Vantage 5.00 and higher no longer uses the Vantage.ini to
connect to report builder.
The report builder.vtg "other parameters" line no longer uses 'Basekey
ini'. It now uses the Progress.ini by default.
Report builder.vtg example:
[Vantage Startup]
Executable=V:\Progress\bin\prorb32.exe
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\Vantage.ini
ParameterFile=V:\Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H mntech -S epic50
TempDirectory=C:\Vntg50
StartupProcedure=
OtherParameters=
--> NOTE: the 'OtherParameters=' line is now blank
Apparently this causes no problem with the database engine because it uses
the registry. You will need to edit the \Progress\Bin\progress.ini to
reference the mapped drive path instead of the physical drive path.
After editing the startup section it should look something like this:
Progress.ini
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DefaultFont=MS Sans Serif, size=8
DefaultFixedFont=Courier New, size=8
DLC=V:\progress
Use-3D-Size=Yes
PROBUILD=V:\progress\PROBUILD
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROBUILD\E
UCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
UseSourceEditor=yes
;EditorConfigPath=V:\prowork\proedit
Where V is a mapped drive.
Pay special attention to the DLC path, and be certain that it says
V:\progress, NOT V:\epic50\progress.
OTHER POSSIBILITES:
Check the Environment Variables in the System Control Panel on the problem
machine. If there is a reference to a DLC, make certain it points to the
correct mapped driver letter.
Check the REGISTRY for any references to DLC. These need to be pointing to
the correct mapped drive for Vantage.
XA500
XA510
XA520
Sent: Thursday, July 24, 2003 12:09 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Convmap.cp error
Hello all,
I have a user who get this error when ever he tries to print/view a custom reports. He is able to print any of the can reports that came with Vantage.
Unable to open convmap file '\convmap.cp'
It only happens on his computer. Any ideas?
Jasper
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705007183:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=30504&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail/S=:HM/A=1663535/rand=485529408>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Hello all,
Jasper
