Copy a field to another window
You should be able to simply link a control to a database field, which a UD field on the PODetail table is considered a database field, in the entry form and link that same field to another control in the Tracker form.
Now when you say ‘nothing is showing up’, what does that mean?  Do you see the control in the tracker and no data shows on a PO that you KNOW has valid data in that field OR you don’t even see the control object in the tracker?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Drew
Sent: Friday, January 17, 2014 12:00 PM
Subject: [Vantage] Re: Copy a field to another window
OK, I think I understand you are saying. Sorry I have only done a couple of these customizations.
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> PO Tracker is a SYSTEM dashboard based on SYSTEM BAQs. You need to create a custom dashboard, create a custom BAQ that adds in the PODetail.Character01 field where you need it to show in your new custom PO Tracker dashboard.
> Sent: Friday, January 17, 2014 1:47 PM
> I just noticed you said "database field". Can I not use a userdefined field?
> --- In vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>, "Drew" <ahsalloum@<mailto:ahsalloum@>> wrote:
> > I have done that exactly, but nothing shows up. I am using the PODetail.Character01 for the dropdown in the PO Entry and I created a textbox in PO Tracker and nothing is showing up. I don't know what the issue is.
> > --- In vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>, <dgodfrey@> wrote:
> > > Drew,
> > > As Karen said, you will now have to customize the PO Tracker. We presume that you are linking the DropDown control to a database field. It is then as easy as creating a textbox in the PO Tracker that is linked to that same field.
------------------------------------------------------------------------------------------------------------------------ CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information (including technology and technical data) which is subject to the U.S. International Traffic in Arms Regulations (ITAR) or Export Administration Regulations (EAR). This information may not be exported, released, or disclosed to foreign persons either inside or outside the United States without first obtaining the proper U.S. export license or written authorization. In addition, the information and articles described herein are either patented or proprietary, and the copying or reproduction thereof is prohibited without ADVANCED Motion Controls prior written consent. If you are not the intended recipient (or have received this e-mail in error), please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance. X3BTB534
Hey guys,
I added a drop down field on my Purchase Order Entry screen to allow the purchasing agent to choose the order's priority.
Now I want to show that selection in read only form in Purchase Order Tracker. How can I do that?
Thanks in advance!
I think you have a couple of options here.  A customization to the PO Tracker to show the field needed is one or copy the PO Tracker dashboard and the underlying BAQ where you want to show this value to add the field into the BAQ.
Sent: Wednesday, January 15, 2014 3:30 PM
Subject: [Vantage] Copy a field to another window
Hey guys,
Thanks in advance!
I did do a customization to the Purchase Order Entry to have a drop down window with 3 criterias, but now I want to be able to show that selection in a field on the Purchase Order Tracker screem. Is that possible?
> Hey guys,
> Thanks in advance!
Drew,
--- In vantage@yahoogroups.com, <dgodfrey@...> wrote:
> Drew,
> --- In vantage@yahoogroups.com, <dgodfrey@> wrote:
> > Drew,
> > Drew,
> > > Drew,
