COS/WIP capture
The problem was that we created a 13th period for end of year closing but
Epicor 9 sets this period to closing so even when doing as you outline here
it didn't work. I ended up deleting the Fiscal year and re-inputting it
without the extra closing period and we could then run it as you describe
Regards
Adrian Lauchlan
Inceptum Projects Ltd
mobile 07852 270968
You can now call me on my Skype Number
skype +44 (0)208 123 5065
The information in this email including any attachments is intended only for
the exclusive use of the person or body it is addressed to. It may contain
confidential and privileged material that may be subject to legal privilege.
It may not be disclosed, disseminated, re-transmitted or distributed without
the permission of the sender. If you have received this email in error,
please delete it from your system and contact the sender. Please note that
it is the recipient's responsibility to check for viruses and Inceptum
Projects Ltd will not be held responsible for any damages arising from virus
infections.
P
Sent: 08 February 2012 19:53
Subject: [Vantage] Re: COS/WIP capture
If December period is still open,
when you run the COS/WIP
under the options change the Ending Date to 12/31/2011. This will
automatically change the start date to 12/1/2011, and should make it post
into December 2011. You should be able to run an inventory/wip
reconciliation for December 2011 unposted transactions to see what is
waiting to post.
"adrian.lauchlan" <adrianlauchlan@...> wrote:
> We went Live at the start of January and posted all our stock qtys and
costs in December. Running COS/WIP Capture keeps posting everything on the
1st of January despite setting everything up to post in December. We have 12
periods in our calendar plus one for end of year closing and this is marked
as closing so I suspect this is why everything is posting on 1st Jan but I
can't work out a way of reopening the period.
> Any ideas?
We went Live at the start of January and posted all our stock qtys and costs in December. Running COS/WIP Capture keeps posting everything on the 1st of January despite setting everything up to post in December. We have 12 periods in our calendar plus one for end of year closing and this is marked as closing so I suspect this is why everything is posting on 1st Jan but I can't work out a way of reopening the period.
Any ideas?
IF the issue is just reopening the period, just go to fiscal period setup and reopen there...
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
Ex scientia, vera
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of adrian.lauchlan
Sent: Tuesday, January 31, 2012 4:34 PM
Subject: [Vantage] COS/WIP capture
Any ideas?
size=2 width="100%" align=center>
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: manasa@...<https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: sentto-20369-107199-1328049225-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=529750294&domain=weldcoa.com>
Message Score: 1
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=529750294&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=529750294&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
The problem is that this 'thirteenth period' is a special one and isn't
listed as a normal period within Fiscal Period setup. When you set up your
periods for a year you can set up the number of periods as 12 and add a
closing period (or more) which you can't see in the normal way. The only
thing I can see is to delete the whole year and re-enter without the closing
period but we have posted items in this year so that would cause problems at
the end of this financial year
Regards
Adrian Lauchlan
mobile 07852 270968
infections.
under the options change the Ending Date to 12/31/2011. This will automatically change the start date to 12/1/2011, and should make it post into December 2011. You should be able to run an inventory/wip reconciliation for December 2011 unposted transactions to see what is waiting to post.
--- In vantage@yahoogroups.com, "adrian.lauchlan" <adrianlauchlan@...> wrote:
> Any ideas?
