Cost Adjustment Table UD
Just as a follow-up, after you use the Extended UD Table Maintenance, you
need to run the data administration tools, and update the UD schema. As a
warning, this can take a long time to run. We've got an OrderDtl table with
100K+ rows, and it took about 8 hours for the UD Schema to finish.
What I found is that the new fields I added as part of OrderDtl_UD show up
within the UI customization with the OrderDtl dataset. However, it appears
there's an issue with BPM's, as I was not able to access those fields from a
BPM. I have a tech support call with Epicor on this.
Kevin Simon
SimsTrak Consulting, LLC
simstrak
Sent: Tuesday, October 18, 2011 10:51 AM
Subject: [Vantage] Re: Cost Adjustment Table UD
I am having this same issue with another table - OrderDtl. I've gone into
the Extended UD Table Maintenance, and added the fields (to table
OrderDtl_UD). However, when I get into Order Entry, I am not seeing the
OrderDtl_UD table, nor are the fields I added showing up under OrderDtl.
Did you ever figure out how to access these fields in a customization?
"jgiese1988" <jgiese@...> wrote:
> Is there a way for me to add UD fields to the Cost Adjustment table. I
tried extended UD maint but was not seeing that table. I want to add a few
fields we will use for helping calculate cost and want them to be stored
with that transaction record. Am I simply missing the table I need to use? I
saw in there Cost Burden table but I didn't believe that is what I was
looking for.
Is there a way for me to add UD fields to the Cost Adjustment table. I tried extended UD maint but was not seeing that table. I want to add a few fields we will use for helping calculate cost and want them to be stored with that transaction record. Am I simply missing the table I need to use? I saw in there Cost Burden table but I didn't believe that is what I was looking for.
I am having this same issue with another table - OrderDtl. I've gone into the Extended UD Table Maintenance, and added the fields (to table OrderDtl_UD). However, when I get into Order Entry, I am not seeing the OrderDtl_UD table, nor are the fields I added showing up under OrderDtl.
