Costing Method Blank Title 69158
Paul,
Is either app customized? (Is it possible someone switched the labels?)
Have you verified it's not a refresh problem? Some customized apps can carry 'ghost' info from the last record to a new record on the form unless you force a refresh.
Rob
--- On Thu, 9/25/08, Cindy House <cindy.house@...> wrote:
Subject: RE: [Vantage] Costing Method
Date: Thursday, September 25, 2008, 12:47 AM
Paul,
We are on version 6 and you can track lots and well as cost them by lot, but
the two are exclusive of each other. The Part Tracker General Button should
show you exactly what is in the Part Master, so I am a little confused as to
how you can see two different things in the two screens. On the Part Master
File, the Costing Method can be chosen when a new part is added. I am not
sure if you set the default or if Vantage set the default, but you can
choose between Average, Last, Standard, and Lot; this shows as a radio
button in the master file, but it just lists the description of the one you
have chosen in the part tracker. Once there is any inventory, you cannot
change the Costing Method, unless you adjust your quantity to zero, change
the costing method (and change your cost), and then adjust your quantity
back to what it was; which is why it would be grayed out. If you choose to
Track Lots, that is independent of the Costing Method that you have chosen,
but it will show the check mark on both the part master and part tracker.
You said that ". where is the costing entered, we show average in the part
master and when we go to part tracker it is showing as lot....how? "
The costing method is entered in the part master file when you choose one of
the radio buttons, which should be reflected in the part tracker as a
description. If the two really are different then you need to call
support, because I would suspect that you have a glitch in your system.
Cindy House
GTech Precision Industries
Corporate Controller
(w)
(f)
(c)
<http://www.gtechpre cision.com> www.gtechprecision. com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Kathy Schaich
Sent: Wednesday, September 24, 2008 3:29 PM
To: vantage@yahoogroups .com
In part master when you add a new part you are able to pick Average,
Standard, Last or Lot. If you have any inventory or demand on that part it
is grayed out and you cannot change the method of costing. We are on 6.1 and
I just looked at Part Master to verify.
Kathy Schaich
Operations Support Manager
Ultra Tool & Manufacturing, Inc.
W169 N5954 Ridgewood Drive
Menomonee Falls, WI 53051
Phone:
Fax:
Toll Free:
kathy.schaich@ ultratoolmfg. com <mailto:kathy. schaich%40ultrat oolmfg.com>
www.ultratoolmfg. com
The information contained in this electronic message (email) and any
attachment(s) to it is/are intended for the exclusive use of the intended
addressee(s) and may contain information that is confidential and/or
privileged and exempt from disclosure under applicable law. If you are not
the intended recipient(s) and have received this communication in error,
please do not distribute it. Instead, please notify Ultra Tool &
Manufacturing, Inc. at or by email at
general@ultratoolmf g.com <mailto:general% 40ultratoolmfg. com> and destroy
all copies of this message and any
attachments. Thank you.
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Manasa Reddy
Sent: September 24, 2008 3:11 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
There is a place to add a lot in 6.0 for a part, I just can't remember
where to do this....that is probably why you are seeing it in part
tracker.
Anyone out there on 6.0 or 6.1? It was the same in both versions for
adding lots.
M. Manasa Reddy
manasa@weldcoa. <mailto:manasa% 40weldcoa. com> com
P:
F:
____________ _________ _________ __
From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
[mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com] On
Behalf
Of Paul Smith
Sent: Wednesday, September 24, 2008 3:09 PM
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
First thing I checked for as well, but no the box is unchecked. It is my
understanding the part tracker, general button showed the part master
information in view only. Strange.
<mailto:vantage% 40yahoogroups. com> ]On
Behalf Of
Manasa Reddy
Sent: Wednesday, September 24, 2008 4:07 PM
And you are version 6....if I remember correctly on the part master, is
there a box for lot tracking? See if that is checked.
It's been a while since I have been on 6.0....
M. Manasa Reddy
P:
F:
Behalf
Of Paul Smith
Sent: Wednesday, September 24, 2008 3:04 PM
Thanks but where is the costing entered, we show average in the part
master
Behalf Of
Manasa Reddy
Sent: Wednesday, September 24, 2008 4:01 PM
Paul,
You can have any of your parts be any costing method...not recommended,
but you can do this. I'm sure there are some environments that need
this as well. The Company config is just what your parts default to
when a new part is entered in to the system.
HTH,
M. Manasa Reddy
P:
F:
Behalf
Of Paul Smith
Sent: Wednesday, September 24, 2008 2:56 PM
To: Vantage
Subject: [Vantage] Costing Method
Question, we are using vantage 6.0 and in our company configuration our
costing method is set up for average costing. Currently we have a part
that
in the part master it shows average costing for that part but in part
tracker the costing method is lot. We also have a part that has the
costing
method last. How is this possible? Thanks in advance
Paul Smith
Inventory Management
233 Ballston Ave
Saratoga Springs NY, 12866
costing method is set up for average costing. Currently we have a part that
tracker the costing method is lot. We also have a part that has the costing
Paul Smith
233 Ballston Ave
518-245-4358
Paul,
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
Thanks but where is the costing entered, we show average in the part master
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
master
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
Sloppy programming. The method in Part Maintenance is the method being used no matter what a read oly tracker might say.
Date: Wednesday, September 24, 2008, 4:04 PM
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com]On Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
Manasa Reddy
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
master
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
tracker.
adding lots.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Paul Smith
Behalf Of
Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
master
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
I'm not sure how it works in 6 but in 8.0 and 8.03 the costing can be
changed on the plant screen of part maintenance to be different from the
details page and the plant screen overrules the details page. I ran into
this problem here using version 8.03. (it might not be the same, but it's
worth a look)
-Adam
_____
Paul Smith
Sent: Wednesday, September 24, 2008 4:09 PM
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of
Manasa Reddy
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
M. Manasa Reddy
manasa@weldcoa. <mailto:manasa%40weldcoa.com> com
P: 630-806-2000
F: 630-806-2001
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Paul Smith
master
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
Kathy Schaich
Phone: 262-703-0455
Fax: 262-703-0468
Toll Free: 800-779-3566
kathy.schaich@...
www.ultratoolmfg.com
Manufacturing, Inc. at 1-800-779-3566 or by email at
general@... and destroy all copies of this message and any
Manasa Reddy
tracker.
adding lots.
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
Behalf Of
Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
master
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
Paul,
Cindy House
(w) 817-539-8014
(f) 817-539-8018
(c) 817-832-8933
<http://www.gtechprecision.com> www.gtechprecision.com
Kathy Schaich
Kathy Schaich
Phone: 262-703-0455
Fax: 262-703-0468
kathy.schaich@... <mailto:kathy.schaich%40ultratoolmfg.com>
general@... <mailto:general%40ultratoolmfg.com> and destroy
Behalf Of
Manasa Reddy
tracker.
adding lots.
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
Behalf Of
Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
master
Behalf Of
Manasa Reddy
Paul,
HTH,
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Paul Smith
To: Vantage
that
costing
Paul Smith
233 Ballston Ave
518-245-4358
