E9.05.602A (implementation)
Hi, I'm looking for some advice on costing methods.
We would like to be able to do the following:
1. Capture the true costs in COS without using variance reports.
2. Update standard costs for manufactured items based on estimated
hours and material cost in BOM.
We are currently live on V6.1 and this does not present a problem as
manufactured parts are set to standard cost but when using make direct
the actual job costs are moved to COS.
The behaviour has been changed in E9 and the make direct option no
longer has the same effect. Any part set to standard cost will result in
a variance regardless of the transaction type.
There is probably an easy solution but I'm not seeing it.
Chris
Chris HenzelEpicor 9 Project ManagerTel: +44 (0)1582 436150Mob: 07836 314164
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this email. Please notify the sender if you have received this email by mistake and delete it from your system.Email transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender does not accept liability for any errors or omissions in the contents of this message, which arise as a result of email transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
Chris
