Gil,
Thanks for taking the time to respond! I appreciate your help and will pass
your comments along to our accounting manager.
\Steve
Sent: Sunday, September 15, 2002 5:10 PM
Subject: [Vantage] RE: Costing Question
Steve,
1. Estimated cost for a quote pulls in the labor cost from the Operation
Master Quoting field.
2. Estimated cost for a job = Operation Master Costing x Estimated
Hours{Set-Up + Production}.
3. Actual Cost when labor is reported against the job is = Actual Labor
Hours x Employee Labor Rate from Employee Master.
When you run a production detail report, there are rows after the Operations
tables that show Estimate and Actual Costs. Columns include Labor Hours
(Set-Up & Prod) and Costs/Labor. Estimated Cost/Labor is calculated from
(2). Actual Cost/Labor is (3).
Given Actual Hours = Estimated Hours, if Reported Employee Rate <> Standard
Labor Rate for the Operation, then you will see a variance. If you leave the
Labor Rate in the Employee Master blank (or zero), then the cost posted when
this particular employee reports hours will be zero. Which is the modern
definition of slavery.
The Employee Labor Rate in the Employee Master is not/never used as the
default in Job Entry and by extension, default calculation of estimated Job
Costs. However, if you know that a specific highly paid employee would have
to do a particular task, say only the CFO can cook a very special product,
you can change the labor rate in the Job/Operation itself. Then the
estimated Job Cost calculation will use this new figure. You can do this
change during Quote Entry, too.
My A$0.02 worth.
Gil Amilbangsa
Australian Healthcare Equipment
gil.amilbangsa@...
________________________________________________________________________
Message: 1
Date: Fri, 13 Sep 2002 13:34:03 -0500
Subject: RE: Costing Question
Edward,
Thanks for your response. I got the part about the estimated job cost; I'm
really curious how Vantage is supposed to act and since the help file isn't
of much value I was hoping that someone could shed some light on the
subject.
Is there anyone else that can shed light on this subject????? PLEASE!!!!
\Steve
Sent: Friday, September 13, 2002 10:53 AM
Subject: RE: [Vantage] Costing Question
The concept is that the estimated job cost is calculated based on the
costing rate for the operation because the actual employee is not known at
that time. What we do is put our standard hourly rate (not the actual
wage
for the employee) into the "shop employee" in JM/MFM/Shop Employee. This
way when the employee clocks in on the job it uses our standard rate.
I have not tested it without rates in the shop employee file so I can't
answer you more specifically.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Sent: Friday, September 13, 2002 11:33 AM
To: Vantage List (E-mail)
Subject: [Vantage] Costing Question
After running Vantage for 4 years, we are finally getting serious about
using Vantage to cost jobs (what a concept, huh?). Consequently, the
accounting manager has been bugging me with a bunch of questions, one of
which has me stumped.
If you go to Operation Master Maintenance, there are fields for Costing
and
Quoting labor rates. I understand that quoting rates are used to
calculate
estimates of the cost for quoting purposes, but I'm not so clear about the
Costing fields. The help screen says, "This appears as the default rate
when this operation is entered in Job Entry. Estimated labor cost will be
calculated by multiplying this rate times the estimate production hours,
plus the estimated setup cost." Huh? Where is this used? Is it used to
cost the job or not? If so, what about the labor rate in the Employee
record.
What I hope the answer is, is that if the Employee labor rate is blank
then
Vantage will use the rate entered in the Operation master.
Can somebody please set me straight on this?
Thanks a bunch!
\Steve
Steve Sanders
Delta Centrifugal Corp
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=232673.2361890.3788200.2225243/D=egroupweb/S=17050071
83:HM/A=1194123/R=0/*http://www.adinsdirect.com/>
<http://us.adserver.yahoo.com/l?M=232673.2361890.3788200.2225243/D=egroupmai
l/S=:HM/A=1194123/rand=475859493>
\Steve
Steve,
My A$0.02 worth.
Gil Amilbangsa
gil.amilbangsa@...
Message: 1
Edward,
subject.
\Steve
wage
Controller
Fax: 401-596-1050
and
calculate
record.
then
Thanks a bunch!
\Steve
Steve Sanders
ADVERTISEMENT
