Could not establish trust relationship for the SSL/TLS secure channel
Hi Ibrahim
Thank you for your suggestion.
I have been followed this below step.
Its working now.
If using a Self-signed Certificate, the cert must be in both the “Personal” and “Trusted Root CA” stores on the local server. To verify:
• In the search window on the server, type in mmc.exe. Click on mmc.exe to launch the MMC console.
• Click on File, Add/Remove Snap-In. Select the “Certificates” Snap-in. Click on the “Add” button. In the new dialog box, select “Computer Account”, click Next, then click Finish, and then click OK.
• In the left pane, expand Certificates, then Personal, and then select Certificates. Note the certificate issued to the FQDN of the ERP server, also note the “Expiration Date”.
• Navigate to the “Trusted Root Certification Authority, Certificates” folder. Scroll through the certificates in that Store and ensure the same certificate noted in the Personal Store is present. If it’s not, navigate back to the Personal Store, right-click on the Cert, select copy, then navigate to the Trusted Root CA Store, right-click on the Certificates Folder and select Paste.
