Under the Actions/User Text pick "show informational message based on the designed template", then click on "Designed" that is in blue and put in a simple message. "Hi from update" is typically the highly sophisticated and detailed message I use :)
Jim Kinneman
Jim Kinneman
--- In vantage@yahoogroups.com, "Wes Hensley" <wes.hensley@...> wrote:
> The Method I'm using is CountTag.Update.
> Having an informational message pop up is a really good idea. How did you
> go about that?
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> jckinneman
> Sent: Wednesday, February 29, 2012 11:05 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Count Tag Inventory BPM
> I may have missed it but which method are you working with?
> What I usually do is just have the method popup up an informational message
> to make sure that the method is actually firing. It is amazing how many
> times I work with what I think is the right method and find out it isn't.
> Leave off any criteria, just have an action with the message. Once you have
> the message appearing, add the criteria and see if the message still
> appears. Then add the action you want.
> Jim Kinneman
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Wes
> Hensley" <wes.hensley@> wrote:
> > You're right. It should be OR. I had actually already tried that with no
> > luck though.
> > _____
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > Doyle, Jason
> > Sent: Wednesday, February 29, 2012 10:20 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: RE: [Vantage] Re: Count Tag Inventory BPM
> > Probably should be OR, not AND
> > Jason Doyle
> > Software Architect
> > Cranel, Inc.
> > Cranel Imaging / ISOdx / Versitec
> > 8999 Gemini Parkway / Columbus, OH 43240
> > p: 614.318.4256 / f: 614.431.8388
> > email: jdoyle@ <mailto:jdoyle%40cranel.com>
> > <mailto:jdoyle@ <mailto:jdoyle%40cranel.com> >
> > cranelimaging.com <http://www.cranelimaging.com/> / isodxsolutions.com
> > <http://www.isodxsolutions.com/> / versitec.com
> > <http://www.versitec.com/>
> > 1985-2010...Celebrating 25 years of excellence, 25 years of evolution
> > Behalf
> > Of Wes Hensley
> > Sent: Wednesday, February 29, 2012 10:14 AM
> > I should clarify something.
> > It is pre-processing. The Condition I am using is as follows:
> > The ttCountTag.Number01 filed has changed from any to any
> > And the ttCountTag.Number02 filed has changed from any to any
> > And the ttCountTag.Number03 filed has changed from any to any
> > The action is
> > For EACH
> > ttCountTag
> > ttCountTag.CountedQty = ttCountTag.Number01 + ttCountTag.Number02 +
> > ttCountTag.Number03
> > END
> > The ttCountTag Number fields are the custom fields I have added. The
> > ttCountTag.CountedQty is the existing Vantage field. Hope this helps to
> > clarify.
> > _____
> > Behalf Of
> > Wes Hensley
> > Sent: Wednesday, February 29, 2012 9:40 AM
> > I am trying to use pre
> > _____
> > Behalf Of
> > jckinneman
> > Sent: Wednesday, February 29, 2012 9:33 AM
> > Which method are you putting it on? Pre or Post?
> > Jim Kinneman
> > Encompass Solutions, Inc
> > "foamdesignit" <wes.hensley@> wrote:
> > > Hi Everyone,
> > > I am trying to write a BPM four Count Tag under material management.
> > Basically what I have done is add a few user defined fields (Number01,
> > Number02, etc) to Count Tag so that if we have inventory for a
> > particular
> > part in different locations and whoever is doing the physical count can
> > input their numbers into the fields as opposed to counting all of the
> > inventory and putting their total in the CountTag.CountedQuanity field.
> > I'm
> > probably not writing the code correctly for the calculation but what
> > I've
> > written is this:
> > > For EACH CountTag:
> > > CountTag.CountedQuantity = Number01 + Number02 + Number03
> > > END
> > > I've never written a calculation for one of these before so I'm pretty
> > sure that's where I'm going wrong but when I hit the "Validate" button,
> > I
> > get no errors it just does not calculate. Does anyone have any ideas?
> > CONFIDENTIALITY NOTICE: This e-mail communication and any attachments may
> > contain confidential and privileged information for the use of the
> > designated recipients named above. If you are not the intended recipient,
> > you are hereby notified that you have received this communication in error
> > and that any review, disclosure, dissemination, distribution or copying of
> > it or its contents is prohibited. If you have received this communication
> in
> > error; please notify Cranel Incorporated immediately by telephone at
> > 614-431-8000 or 800-288-3475 and destroy all copies of this communication
> > and any attachments.
