Country listing / drop-down NOT up-to-date
Thanks, Cathy and Manasa.  I can modify a few via Epicor, for now, until I have a good ISO-locked list to DMT.
Regards …
Shaun W M Scott
Senior Systems Analyst - MRP
Information (including any attachments) contained in this electronic transmission is a PRIVILEGED AND CONFIDENTIAL COMMUNICATION. It is for the sole use of the sender and the entity named above. If you received this electronic transmission in error, you are required to immediately delete it in its entirety without making a copy. Further dissemination is absolutely prohibited. Thank you.   ­­
Hello / Whomever can assist:
My team recently began adding new domestic and international shipment addresses to our Live DB.  However, the Country list is particularly out of date; is that normal?
I just want to confirm that this sort of thing is either supposed to be handled by each E’user or normal updates are to be pushed by Epicor.  We are running 9.05 702A, just to be clear.
Thanks and regards …
Shaun W M Scott
You need to maintain the Country list.
It is not provided by Epicor.
Sent: Friday, November 14, 2014 9:16 AM
Subject: [Vantage] Country listing / drop-down NOT up-to-date
Shaun W M Scott
There is a list of ISO standard country listings on the internet.  Use that to import a complete list so that your updating is at a minimum.
Manasa
Sent: Friday, November 14, 2014 10:19 AM
Subject: RE: [Vantage] Country listing / drop-down NOT up-to-date
Subject: [Vantage] Country listing / drop-down NOT up-t o-date
Shaun W M Scott
Senior System s Analyst - MRP
