Kinda scary you can change the dates on these screens if you ask me.
~Charlie
_____
Nigel Kerley
Sent: Tuesday, July 28, 2009 7:55 AM
Subject: [Vantage] Re: Crazy Part Tran History
The date would normally be set to the current day by default, but if the
user changed it - say on a shipment, inv transfer, qty adjustment - they may
have entered an incorrect date in error.
Nigel.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
Wilson" <foamdesigncsw@...> wrote:
Behalf Of
~Charlie
_____
Nigel Kerley
Nigel.
>[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> How does one set a date on a transaction? I thought they were picked up by
> the system.
> ~Charlie
> _____
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Behalf Of
> Nigel Kerley"Charlie
> Sent: Tuesday, July 28, 2009 4:23 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Hi Charlie,
> This may be a silly suggestion, but by chance would someone have entered a
> transaction with an incorrect date? Say way in the past, or even in the
> future?
> A future transaction may not show on the Part Transaction History Tracker
> since the Cut-Off Date defaults to today.
> Try setting it to way in the future and then comparing the SysDate and
> TranDate columns.
> May turn up something.
> Nigel.
> Wilson" <foamdesigncsw@> wrote:a
> > All,
> > We are on 407 currently. We have a specific part that all the sudden has
> > very strange transaction history table. The part is now showing negativeof
> > quantity numbers all the way back to the begin of the part history. No I
> > understand that a negative quantity is not a problem but I'm saying 90%
> > the quantities are negative. From what I can figure out vantagecalculates
> > these quantities by taking the current on hand quantity in the bins andbegan
> > adding and subtracting each transaction all the way back to when we
> toable
> > use the system. There is no other piece of data stating at this point in
> > time there was this amount on hand in the system other than this
> calculated
> > field. We have screen shots showing the trans log history was okay up
> until
> > the 21st of this month where the quantities are okay not many negs.
> Barring
> > the idea that some one back doored the system and changed the data
> directly
> > because I'm pretty sure I'm the only one with enough knowledge to be
> tochange
> > do this. This means that a transaction took place that was able to
> > the bin quantity but we aren't seeing the subsequent transaction log[Non-text portions of this message have been removed]
> entry.
> > ~Charlie
