True enough on the languages. I will setup some tests today.
Thanks for the suggestion.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of brenda mohr
Sent: Thursday, April 25, 2013 8:31 AM
Subject: [Vantage] RE: Create Excel file from bpm
Seems to me yes.... It can be gotten around by using the old ASCII Characters. (ie CHR(13) + CHR(10) for CRLF) Same Ol Same Ol You might have to experiment. Maybe delimit w/ some "safe" character (PartNum + CHR(59) + PartDesc) OR (PartNum + " ; " + PartDesc). I may even have used the INDEX / REPLACE to make ' ''' so it does parse correct depending on syntax. After ½ dozen languages or so you forget what is required by each ~ alas...
Brenda
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Greg Payne
Sent: Thursday, April 25, 2013 8:03 AM
it is a list of parts for a vendor to quote and return the spreadsheet to us. This would be simpler and not involve using Excel on the server.
are there any issues to watch for in building the comma delimited string? Like a part or description with a comma or single quote.
Greg
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of brenda mohr
Sent: Thursday, April 25, 2013 7:19 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
You say "create generic" How generic? I use the following code and my users just open it in excel all is good...
DEF VAR Outfile AS Char format 'X(1000)' no-undo.
DEF VAR OString as Char format 'X(1000)' no-undo.
Outfile = "\\HUMEPICOR\SCWork\BrendasJOBTEST.csv<file:///<file:///\\><file:///<file:///\\>\\>\\HUMEPICOR\SCWork\BrendasJOBTEST.csv>".
OUTPUT TO VALUE(Outfile).
OString = "Available".
PUT UNFORMATTED Ostring SKIP(0).
Brenda
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Greg Payne
Sent: Wednesday, April 24, 2013 4:44 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Create Excel file from bpm
I am having a few issues with a bpm I am writing to create an excel file. I started with some sample code and got most of it working. Excel is on a Server 2008R2 64bit machine.
the saveas and the workbook:close are throwing errors.
Invalid component-handle referenced while processing method/statement: CLOSE. is from theWorkBook
On the saveas, I want to overwrite the file. How would I set the XLSaveConflictResulution to 2, for the local user's changes are always accepted.
I have tried a lot of variations that I have found when searching, but not solved it yet.
Thanks for any suggestions.
Greg Payne
/* create generic excel file */
DEFINE VARIABLE vchExcelAppl AS COM-HANDLE NO-UNDO.
DEFINE VARIABLE vchWorkBook AS COM-HANDLE NO-UNDO.
DEFINE VARIABLE vchWorkSheet AS COM-HANDLE NO-UNDO.
DEFINE VARIABLE MyVariable AS CHARACTER NO-UNDO.
define variable InfoMsg as character init ''.
CREATE "Excel.Application" vchExcelAppl.
vchExcelAppl:VISIBLE = false.
vchWorkBook = vchExcelAppl:WorkBooks:Open("E:\EpicorOUT\RFQTemplate.xlsx").
vchWorkSheet = vchExcelAppl:Sheets:Item(1).
/* Set a Value */
vchWorkSheet:Range("A2"):Value = "My Value".
/* Get A Value */
MyVariable = vchWorkSheet:Range("A2"):Text.
message "Value is " + string(MyVariable).
/* Save File */
vchWorkBook = vchWorkBook:SaveAs("E:\EpicorOUT\RFQ_Vendor.xlsx",,,,,,,2).
vchWorkBook:CLOSE().
RELEASE OBJECT vchWorkSheet.
RELEASE OBJECT vchWorkBook.
vchExcelAppl:Quit.
RELEASE OBJECT vchExcelAppl.
ASSIGN vchWorkSheet = ?
vchWorkBook = ?
vchExcelAppl = ?.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg
Brenda
Greg
Brenda
Greg Payne
/* Set a Value */
/* Get A Value */
/* Save File */
vchExcelAppl:Quit.
vchWorkBook = ?
vchExcelAppl = ?.
