Ok I wrote a procedure to do this, and I still get this error. I have no idea what I am missing
** ABL Debug-Alert Stack Trace **
[GetPartPlant bpm/customcode/GetNewPartPlant.p (e:\Epicor905\Server\bpm\customcode\GetNewPartPlant.p) at line 6936
UpdatePost230_A2 bo/Part/Part.p (e:\Epicor905\bpmExec\TrainingBPM\bo\Part\Part.r) at line 10675
Update bo/Part/Part.p (e:\Epicor905\bpmExec\TrainingBPM\bo\Part\Part.r) at line 12675
Update bo/Part/Sink.p (e:\Epicor905\Server\bo\Part\Sink.r) at line 2847
(Procedure: 'GetPartPlant bpm/customcode/GetNewPartPlant.p' Line:6935) MJP30T
** No ttPart record is available. (91)
Most Recent Procedure:
{Bpm/Bpm.i &OBJECT_NAME="Part" &BPM_BO_SOURCE_BO=1 &CUSTCODE=1 &CUR-COMP=""}
{Bpm/MiscCallContext.i}
{core/UserDefinedData.i "new global"}
procedure GetPartPlant:
define input-output parameter dataset for PartDataSet.
define variable ipart as Character.
Define buffer altTTPartPlant for ttPartPlant.
Define buffer altTTPart for ttPart.
{&TRY_PRIVATE}
FOR EACH TTPART NO-LOCK.
ipart= TTPART.PartNum.
define variable NewPlant as handle no-undo.
run bo/Part/Part.P Persistent set NewPlant no-error.
if not valid-handle(NewPlant ) or error-status:error then
do:
Message "Unable To Create Part Plants".
return.
end.
DEFINE VARIABLE PLANTEXISTS AS CHARACTER INITIAL '' NO-UNDO.
DEFINE VARIABLE TEST AS CHARACTER INITIAL '' NO-UNDO.
FOR EACH PARTPLANT WHERE PARTPLANT.Company=TTPART.COMPANY AND PARTPLANT.PartNum=TTPART.PartNum NO-LOCK.
IF AVAILABLE PARTPLANT THEN DO:
PLANTEXISTS=PLANTEXISTS + PARTPLANT.Plant + ', '.
END.
END.
FOR EACH PLANT WHERE PLANT.Company=ttpart.company AND (PLANTEXISTS MATCHES '*' + PLANT.PLANT + '*')=FALSE NO-LOCK.
IF AVAILABLE PLANT THEN DO:
FOR EACH UD36 WHERE UD36.COMPANY=PLANT.Company AND UD36.Key1=PLANT.PLANT NO-LOCK.
IF AVAILABLE UD36 THEN DO:
run GetNewPartPlant in NewPlant({&input-output_dataset_PartDataSet},input ipart).
Message Plant.Plant.
ttPartPlant.Company = TTPART.Company.
ttPartPlant.PartNum = TTPART.PARTNUM.
ttPartPlant.Plant = PLANT.Plant.
ttPartPlant.ReOrderLevel =FALSE.
TTPARTPLANT.BackFlush=FALSE.
TTPARTPLANT.CostMethod='A'.
TTPARTPLANT.TransferLeadTime=3.
TTPARTPLANT.DaysOfSupply=14.
TTPARTPLANT.ProcessMRP=TRUE.
TTPARTPLANT.GenerateSugg=TRUE.
TTPARTPLANT.BuyToOrder=FALSE.
TTPARTPLANT.PhantomBOM=FALSE.
TTPARTPLANT.NonStock=FALSE.
TTPARTPLANT.QtyBearing=TRUE.
TTPARTPLANT.KitAllowUpdate=FALSE.
TTPARTPLANT.KitAllowChangeParms=FALSE.
TTPARTPLANT.PrimWhse=UD36.SHORTCHAR01.
TTPARTPLANT.SourceType= IF PLANT.PLANT='MJP02' THEN TTPART.TypeCode ELSE UD36.ShortChar03.
TTPARTPLANT.TransferPlant=UD36.SHORTCHAR04.
/*TTPARTPLANT.VendorNumVendorID=''.*/
/*TTPARTPLANT.PurPoint=''.*/
/*TTPARTPLANT.BuyerID=''.*/
/*TTPARTPLANT.PersonID=''.*/
TTPARTPLANT.LeadTime=0.
TTPart.Rowmod='U'.
run Update in NewPlant({&input-output_dataset_PartDataset}).
Message "i got here 6".
end. /*avail ud36*/
end. /*for ud36*/
end. /*if avail plant*/
end. /*each plant*/
end. /*Each ttpart*/
{&CATCH_PRIVATE}
end procedure.
---In vantage@yahoogroups.com, <livingstonmh@...> wrote:I am trying to create a BPM that will create all of the Partplant records when a new part is entered. I have it pulling some of the defaults I need off of a UD table.
I tried using an Updateable BAQ BPM as an example, but I keep getting errors in the server like:
"createConstants" was not found. (293)
or when I remove that part of the code:
"ZeroizeBuf" was not found. (293)
and when i removed that i got:
This is my first venture into creating records with a BPM so I am a bit lost. Follwing is my current code:
def var NEWPLANT as handle no-undo.
def var errorsOccured as logical no-undo.
run bo/Part/Part.p persistent set NEWPLANT.
run createConstants.
do on error undo, leave:
dataset PartDataSet:empty-dataset().
create ttPartPlant.
run ZeroizeBuf(temp-table ttPartPlant:default-buffer-handle).
create ttPart.
run ZeroizeBuf(temp-table ttPart:default-buffer-handle).
ttPart.RowIdent = '#' + ttResults.RowIdent.
ttPart.Company = Constants.CurrentCompany.
ttPart.PartDescription = ttResults.Part_PartDescription.
ttPart.PartNum = ttResults.PartPlant_PartNum.
run GetNewPartPlant in NEWPLANT(input-output dataset PartDataSet, true, true, output dataset BOUpdErrorDataset, output errorsOccured).
delete object NEWPLANT.
END.
