I need some help making a customisation to create a pdf of a PO, then open an email message with that PDF attached and leave it open for the user to check before they press the send button. I am having a lot of trouble getting the PO saved as pdf. When I try to export the report from a Cystal ReportDocument it sends an exception saying the database logon failed.
I have followed the trace of doing this manually and read up on previous posts here: http://tech.groups.yahoo.com/group/vantage/message/100387 but I cant figure out what I am doing wrong....
I also looked at using APM to generate the pdf but APM wont let me name the file it creates so I can't go fetch it...
Here is the code.....
private void epiButtonC1_Click(object sender, System.EventArgs args)
EpiDataView edvPOHeader = (EpiDataView)oTrans.EpiDataViews["POHeader"];
int PONUM;
string Approved;
// check if there is data loaded into the form. if not return from method.
if ( (bool)edvPOHeader.HasRow == false )
MessageBox.Show("No Data to email ...");
return;
// Get data from the form
Approved = (string)edvPOHeader.dataView[edvPOHeader.Row]["ApprovalStatus"];
PONUM = (int)edvPOHeader.dataView[edvPOHeader.Row]["PONum"];
if (Approved == "A")
// check the supplier has an email address in Purchase Point.
// grab the email address textbox (this textbox is a customisation) so we can check and get the address if it is there.....
string PPemailAddress;
PPemailAddress = epiTextBoxC3.Text;
if (PPemailAddress == "")
MessageBox.Show("No Email address. Add address to Supplier Purchase Point");
return; // bailout - no email address...
// Make the report from the PO data
POForm Form = new POForm(((Session)oTrans.Session).ConnectionPool);
POFormDataSet POFormDS;
POFormDS = Form.GetNewParameters();
POFormDS.POFormParam[0].PONum = PONUM;
POFormDS.POFormParam[0].ReportStyleNum = 1001;
Form.SubmitToAgent(POFormDS, "SystemAgent", 0, 0, "Epicor.Mfg.UIRtp.POForm"); //Submit the report to be generate by the system agent.
// Need to wait for report to be generated before continuing...
System.Threading.Thread.Sleep(30000); // not the best method but I have bigger issues....
// make the crystal report
ReportDocument repDoc = new ReportDocument();
repDoc.Load(@"\\XXXX\Epicor905\Server\reports\CustomReports\POForm_TMT.rpt"); //get report definition....Once this is working should lookup the report location.
// get report data. Make a ReportMonitor, use it to get a reportmonitor dataset. The reportmonitor dataset will have the sysrowID of the report
// we want, we can then use the sysrowID to get the report data to put into the crystal report.
ReportMonitor RM = new ReportMonitor(((Session)oTrans.Session).ConnectionPool);
ReportMonitorDataSet RMds;
bool morepages;
ReportDataDataSet reportDS;
RMds = RM.GetRowsKeepIdleTime(@"WorkStationID ='ENG01 1'", 0, 0, out morepages); // this gets all reports from my workstation which during testing have all been the same PO.
MessageBox.Show("Report SysrowID is " + RMds.SysRptLst[0].SysRowID); // for testing
reportDS = RM.GetReportData(RMds.SysRptLst[0].SysRowID); // get the report data using the sysrowID of the first report from the Reportmonitor dataset.
repDoc.SetDataSource(reportDS);
repDoc.Refresh();
MessageBox.Show("finished creating report");
// make a pdf of the PO from the report
string FileName = @"\\XXXX\EpicorData\test.pdf";
ExportOptions CrExportOptions ;
DiskFileDestinationOptions CrDiskFileDestinationOptions = new DiskFileDestinationOptions();
PdfRtfWordFormatOptions CrFormatTypeOptions = new PdfRtfWordFormatOptions();
CrDiskFileDestinationOptions.DiskFileName = FileName;
CrExportOptions = repDoc.ExportOptions;
CrExportOptions.ExportDestinationType = ExportDestinationType.DiskFile;
CrExportOptions.ExportFormatType = ExportFormatType.PortableDocFormat;
CrExportOptions.DestinationOptions = CrDiskFileDestinationOptions;
CrExportOptions.FormatOptions = CrFormatTypeOptions;
repDoc.Export(); // ********************** ERROR OCCURS ON THIS LINE. DB LOGIN FAILED???#$@$#@
MessageBox.Show("finished saving report as pdf");
// create email message
try
Outlook.Application oApp = new Outlook.Application();
Outlook.MailItem oMsg = (Outlook.MailItem)oApp.CreateItem(Outlook.OlItemType.olMailItem);
Outlook.Inspector MsgInspector = oMsg.GetInspector;
string Signature = oMsg.HTMLBody; //capture signature for appending to custom message later.
oMsg.Subject = "**** TESTING ERP SYSTEM PLEASE IGNORE **** PO number " + PONUM.ToString();
oMsg.HTMLBody = "<body lang=EN-AU ><div class=WordSection1><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please see attached purchase order, and Total Marine Technology Purchase Order Terms and Conditions.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p>Â </o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please let me know if there are any problems.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p>Â </o:p></span></p><p class=MsoNormal><span style='color:red;mso-fareast-language:EN-AU'>Kindly acknowledge receipt of this Purchase Order. Â <o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D'><o:p>Â </o:p></span></p><div><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Kind Regards,<o:p>" + Signature;
Outlook.Recipients oRecips = (Outlook.Recipients)oMsg.Recipients;
// Change the recipient in the next line if necessary.
Outlook.Recipient oRecip = (Outlook.Recipient)oRecips.Add(PPemailAddress);
oRecip.Resolve();
// Attach pdf of PO, terms, and any other attachments to PO.
oMsg.Attachments.Add(@"\\XXXX\Engineering\Temp\Purchase Order Terms and Conditions.pdf",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
oMsg.Attachments.Add(@"\\XXXX\EpicorData\test.rpt",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
MsgInspector.Activate(); // shows the new email message as topmost window.
//Clean up
oRecips = null;
oRecip = null;
oMsg = null;
oApp = null;
catch (Exception Ex)
MessageBox.Show("Tried to email PO but failed");
else
MessageBox.Show("PO must be approved before it can be sent out");
Dave Thomas
--- In vantage@yahoogroups.com, "brettmanners" <bmanners@...> wrote:
> Greetings all,
> // ** Place Event Handling Code Here **
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Bobby
> Greetings all,
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ralmon64
Sent: Tuesday, May 28, 2013 5:48 AM
Subject: [Vantage] Re: Create PDF of PO report then email
If you do get it to work like this please let me know as i would be very interested in this as well. Right now i am using APM. There is a checkbox that you can use in the newest version of APM which allows you to name your pdf file with one of the properties that you have selected. but i don't like that the email is automatically sent and that it is hard to verify who it went to and if it actually went out to the suppliers at all.
Bobby
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "brettmanners" <bmanners@...<mailto:bmanners@...>> wrote:
> Greetings all,
> int PONUM;
> string Approved;
> return;
> repDoc.Load(@"\\XXXX\Epicor905\Server\reports\CustomReports\POForm_TMT.rpt<file:///\\XXXX\Epicor905\Server\reports\CustomReports\POForm_TMT.rpt>"); //get report definition....Once this is working should lookup the report location.
> bool morepages;
> repDoc.Refresh();
> string FileName = @"\\XXXX\EpicorData\test.pdf<file:///\\XXXX\EpicorData\test.pdf>";
> try
> oMsg.HTMLBody = "<body lang=EN-AU ><div class=WordSection1><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please see attached purchase order, and Total Marine Technology Purchase Order Terms and Conditions.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please let me know if there are any problems.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:red;mso-fareast-language:EN-AU'>Kindly acknowledge receipt of this Purchase Order. <o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D'><o:p> </o:p></span></p><div><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Kind Regards,<o:p>" + Signature;
> oRecip.Resolve();
> oMsg.Attachments.Add(@"\\XXXX\Engineering\Temp\Purchase Order Terms and Conditions.pdf<file:///\\XXXX\Engineering\Temp\Purchase%20Order%20Terms%20and%20Conditions.pdf>",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
> oMsg.Attachments.Add(@"\\XXXX\EpicorData\test.rpt<file:///\\XXXX\EpicorData\test.rpt>",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Try this for your Crystal portion:
Calvin Dekker
[cid:image001.jpg@01CE5B94.54FC4770]<http://www.codabears.com/>
(630) 672-7688 x1484
*Solutions for Epicor users.
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of brettmanners
Sent: Sunday, May 26, 2013 8:25 PM
Subject: [Vantage] Create PDF of PO report then email
Greetings all,
int PONUM;
string Approved;
return;
bool morepages;
repDoc.Refresh();
try
oRecip.Resolve();
//Clean up
oRecips = null;
oRecip = null;
oMsg = null;
oApp = null;
else
Probably helps more if I try attaching the code to the message too. :)
String myRpt = "";
String rpt = "";
String myPDFName = String.Format("PO-{0}-{1:yyyyMMdd-HHmmssff}.pdf", PONum, System.DateTime.Now);
String myPDF = String.Format("{0}{1}", RptPath, myPDFName);
String RptPath = "\\epicordata\reports\MyPOs\<file:///\\epicordata\reports\MyPOs\>";
String AppPath = "\\Epicor905\";
DataSet rptData = new DataSet;
rptData.ReadXml(FileName);
IF (File.Exists(myPDF)) {
File.Delete(myPDF);
ReportDocument myCrystal = New CrystalDecisions.CrystalReports.Engine.ReportDocument;
String myReport = AppPath + myRpt;
myCrystal.Load(myReport);
myCrystal.SetDataSource(rptData);
myCrystal.Refresh();
myCrystal.ExportToDisk(CrystalDecisions.Shared.ExportFormatType.PortableDocFormat, myPDF);
Calvin Dekker
[cid:image001.jpg@01CE5B95.56B350D0]<http://www.codabears.com/>
Greetings all,
int PONUM;
string Approved;
return;
bool morepages;
repDoc.Refresh();
try
oRecip.Resolve();
//Clean up
oRecips = null;
oRecip = null;
oMsg = null;
oApp = null;
else
Click the Routing List Groups tab.
Click Edit.
On the window that opens is a section called Output. You can select to use the keyfield of the document type for the name. When I selected it for our packing slips they come out like....
14722.00_165_0_146T0.pdf
The first set of numbers being the packing slip number.
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> Hey, where is the checkbox you mention that will allow you to name your PDF with one of the properties in APM?
> Thanks,
> Bobby
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "brettmanners" <bmanners@<mailto:bmanners@>> wrote:
> > Greetings all,
> > int PONUM;
> > string Approved;
> > return;
> > bool morepages;
> > repDoc.Refresh();
> > try
> > oRecip.Resolve();
> > //Clean up
> > oRecips = null;
> > oRecip = null;
> > oMsg = null;
> > oApp = null;
> > else
Also for this to work, you need to set the Key Property Checkbox
Document Type
Properties
Edit
Select the Field you want.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of justincalbraze
Sent: Tuesday, May 28, 2013 10:04 AM
Under Routing Lists, Open one of them.
Click Edit.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...<mailto:kschoenung@...>> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of ralmon64
> Thanks,
> Bobby
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "brettmanners" <bmanners@<mailto:bmanners@>> wrote:
> > Greetings all,
> > int PONUM;
> > string Approved;
> > return;
> > repDoc.Load(@"\\XXXX\Epicor905\Server\reports\CustomReports\POForm_TMT.rpt<file:///<file:///\\>\\XXXX\Epicor905\Server\reports\CustomReports\POForm_TMT.rpt>"); //get report definition....Once this is working should lookup the report location.
> > bool morepages;
> > repDoc.Refresh();
> > string FileName = @"\\XXXX\EpicorData\test.pdf<file:///<file:///\\>\\XXXX\EpicorData\test.pdf>";
> > try
> > oMsg.HTMLBody = "<body lang=EN-AU ><div class=WordSection1><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please see attached purchase order, and Total Marine Technology Purchase Order Terms and Conditions.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please let me know if there are any problems.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:red;mso-fareast-language:EN-AU'>Kindly acknowledge receipt of this Purchase Order. <o:p></o:p></span></p><p cla ss=MsoNormal><span style='color:#1F497D'><o:p> </o:p></span></p><div><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Kind Regards,<o:p>" + Signature;
> > oRecip.Resolve();
> > oMsg.Attachments.Add(@"\\XXXX\Engineering\Temp\Purchase Order Terms and Conditions.pdf<file:///<file:///\\>\\XXXX\Engineering\Temp\Purchase%20Order%20Terms%20and%20Conditions.pdf>",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
> > oMsg.Attachments.Add(@"\\XXXX\EpicorData\test.rpt<file:///<file:///\\>\\XXXX\EpicorData\test.rpt>",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
> > //Clean up
> > oRecips = null;
> > oRecip = null;
> > oMsg = null;
> > oApp = null;
> > else
I am trying to get Calvin's suggestion to work as that will put all the customisation in one place. I am still having trouble though...
I am a bit confused about these lines:
> String myPDFName = String.Format("PO-{0}-{1:yyyyMMdd-HHmmssff}.pdf", PONum, System.DateTime.Now);it looks like RptPath is used before it has been declared? and I don't understand the "<file:///\\" part?
Calvin can you post the rest of the code?
Thanks Brett
--- In vantage@yahoogroups.com, Calvin Dekker <calvind@...> wrote:
> Brett -
> String myRpt = "";
> String rpt = "";
> File.Delete(myPDF);
> Calvin Dekker
> [cid:image001.jpg@...]<http://www.codabears.com/>
> Greetings all,
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Here is the code:
// Custom code for POEntryForm
// Created: 15/02/2013 9:50:29 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.BO;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
using Outlook = Microsoft.Office.Interop.Outlook;
using Epicor.Mfg.Rpt;
using CrystalDecisions.CrystalReports.Engine;
using CrystalDecisions.Shared;
using Epicor.Mfg.Core;
using System.IO;
public class Script
this.epiButtonC1.Click += new System.EventHandler(this.epiButtonC1_Click);
this.epiButtonC1.Click -= new System.EventHandler(this.epiButtonC1_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
// This customisation requires 3 .dll files for the email automation to work. These files must exsist in the client
// folder on the client machine before the customistaion can load.
// The files are:
// - Microsoft.Office.Interop.Outlook.dll
// - CrystalDeceisions.Shared.dll
// - CrystalDecsicions.CrystalReports.Engine.dll
int PONUM;
string Approved;
return;
// set the PO number and report style and submit the form to the system agent.
POFormDS.POFormParam[0].WorkstationID = String.Format("{0}",PONUM); // Using the PO number as the WorkstationID so it is easy to reteive this report
repDoc.Load(@"\\#####\Epicor905\Server\reports\CustomReports\POForm.rpt"); //get report definition....Once this is working should lookup the report location.
bool morepages;
ReportDataDataSet reportDS = new ReportDataDataSet();
// setup a loop to look for when the report has been generated.
int timer=0;
RMds = RM.GetRowsKeepIdleTime(@"WorkStationID ='"+PONUM+"'", 0, 0, out morepages);
while (RMds.SysRptLst.Count == 0 );
System.Threading.Thread.Sleep(1000);
timer = timer + 1;
if (timer > 30)
MessageBox.Show("Well, I have been trying to make a pdf of the PO for a while now and I just can't do it....I give up!");
return;
string sFilePath;
sFilePath = RMds.SysRptLst[0].FileName.ToString();
reportDS.ReadXml(sFilePath , System.Data.XmlReadMode.Auto);
reportDS.WriteXml(sFilePath, System.Data.XmlWriteMode.WriteSchema);
repDoc.Refresh();
string FileName = String.Format(@"\\###\EpicorData\{0}.pdf", PONUM);
repDoc.Export();
try
oMsg.Subject = "**** TESTING ERP SYSTEM PLEASE IGNORE **** TMT PO number " + PONUM.ToString();
oRecip.Resolve();
oMsg.Attachments.Add(@"\\####\Purchase Order Terms and Conditions.pdf",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
oMsg.Attachments.Add(FileName,Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);
//Clean up
oRecips = null;
oRecip = null;
oMsg = null;
oApp = null;
File.Delete(FileName);
MessageBox.Show("Tried to email PO but failed.....Really, I did try, I dont know what went wrong...better call the system admin");
else
> Greetings all,
> int PONUM;
> string Approved;
> return;
> repDoc.Load(@"\\XXXX\Epicor905\Server\reports\CustomReports\POForm.rpt"); //get report definition....Once this is working should lookup the report location.
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Ok, been trying to get this to work for a while now and I can't find the DLL files. I have run searches on my computer and tried to browse to different paths, the only thing i can find are MSIL with these names, and i can't copy these. So what is the best way move the DLL file into the client folder.
Bobby
---In vantage@yahoogroups.com, <brett.manners@...> wrote:I managed to get this working with some help from out VAR. In the end we had to rebuild the PO report in crystal as the dataset I was getting from Epicor didn't match what the report was expecting for some reason.
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
oRecip.Resolve();
//Clean up
oRecips = null;
oRecip = null;
oMsg = null;
oApp = null;
else
> Greetings all,
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
TADA it all works, maybe this will work for you. I was doing the same thing exporting from Cyrstal using code.
On Mon, Sep 30, 2013 at 12:40 PM, <ralmon@...> wrote:Â<div> <p></p><p>Ok, been trying to get this to work for a while now and I can't find the DLL files. I have run searches on my computer and tried to browse to different paths, the only thing i can find are MSIL with these names, and i can't copy these.  So what is the best way move the DLL file into the client folder. </p>
Bobby
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
<br> Outlook.Recipients oRecips = (Outlook.Recipients)oMsg.Recipients;<br> // Change the recipient in the next line if necessary.<br> Outlook.Recipient oRecip = (Outlook.Recipient)oRecips.Add(PPemailAddress);<br> oRecip.Resolve();<br> <br> // Attach pdf of PO, terms, and any other attachments to PO.<br> oMsg.Attachments.Add(@"\\####\Purchase Order Terms and Conditions.pdf",Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);<br> oMsg.Attachments.Add(FileName,Outlook.OlAttachmentType.olByValue, Type.Missing,Type.Missing);<br> <br> MsgInspector.Activate(); // shows the new email message as topmost window.<br> <br> //Clean up<br> oRecips = null;<br> oRecip = null;<br> oMsg = null;<br> oApp = null;<br> File.Delete(FileName);<br> }<br> catch (Exception Ex)<br> {<br> MessageBox.Show("Tried to email PO but failed.....Really, I did try, I dont know what went wrong...better call the system admin");<br> }<br> }<br> else<br> MessageBox.Show("PO must be approved before it can be sent out");<br>
> Greetings all,
> I have followed the trace of doing this manually and read up on previous posts here: http://tech.groups.yahoo.com/group/vantage/message/100387 but I cant figure out what I am doing wrong…>
> I also looked at using APM to generate the pdf but APM wont let me name the file it creates so I can't go fetch it…
> Here is the code…
> int PONUM;
> string Approved;
> MessageBox.Show("No Data to email …");
> return;
> // grab the email address textbox (this textbox is a customisation) so we can check and get the address if it is there…
> return; // bailout - no email address…
> // Need to wait for report to be generated before continuing…
> System.Threading.Thread.Sleep(30000); // not the best method but I have bigger issues…
> repDoc.Load(@"\\XXXX\Epicor905\Server\reports\CustomReports\POForm.rpt"); //get report definition…Once this is working should lookup the report location.
> bool morepages;
> repDoc.Refresh();
> try
> oMsg.Subject = "** TESTING ERP SYSTEM PLEASE IGNORE **** PO number " + PONUM.ToString();
> oMsg.HTMLBody = "<body lang=EN-AU ><div class=WordSection1><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please see attached purchase order, and Total Marine Technology Purchase Order Terms and Conditions.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p>Â </o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please let me know if there are any problems.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p>Â </o:p></span></p><p class=MsoNormal><span style='color:red;mso-fareast-language:EN-AU'>Kindly acknowledge receipt of this Purchase Order. Â <o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D'><o:p>Â </o:p></span></p><div><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Kind Regards,<o:p>" + Signature;>
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
</div> <div style="color:#fff;min-height:0;"></div>
I'm not having a logon issue yet...I receive the following errors when I post into the Script editor and change all the database locations to our DB name. I have put the 3 DLL files into the client folder on my machine.
Error: CS0234 - line 20 (20) - The type or namespace name 'Rpt' does not exist in the namespace 'Epicor.Mfg' (are you missing an assembly reference?)
Error: CS0246 - line 21 (21) - The type or namespace name 'CrystalDecisions' could not be found (are you missing a using directive or an assembly reference?)
Error: CS0246 - line 22 (22) - The type or namespace name 'CrystalDecisions' could not be found (are you missing a using directive or an assembly reference?)
Error: CS0234 - line 19 (19) - The type or namespace name 'Office' does not exist in the namespace 'Microsoft' (are you missing an assembly reference?)
---In vantage@yahoogroups.com, <jose@...> wrote:So I just went through this same problem with Databse Logon and I fixed it as follows
Open the Report in Crystal Developer, -> Load in a NEW XML file (rencelty printed) -> Refresh the Data Source (in my case it said the DB was out of date and fixed a field or two for me)Save the FileTADA it all works, maybe this will work for you. I was doing the same thing exporting from Cyrstal using code.
On Mon, Sep 30, 2013 at 12:40 PM, <ralmon@...> wrote:<div> <p>Ok, been trying to get this to work for a while now and I can't find the DLL files. I have run searches on my computer and tried to browse to different paths, the only thing i can find are MSIL with these names, and i can't copy these. So what is the best way move the DLL file into the client folder. </p>
Bobby
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
> Greetings all,
> Here is the code…
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oMsg.HTMLBody = "<body lang=EN-AU ><div class=WordSection1><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please see attached purchase order, and Total Marine Technology Purchase Order Terms and Conditions.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Please let me know if there are any problems.<o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'><o:p> </o:p></span></p><p class=MsoNormal><span style='color:red;mso-fareast-language:EN-AU'>Kindly acknowledge receipt of this Purchase Order. <o:p></o:p></span></p><p class=MsoNormal><span style='color:#1F497D'><o:p> </o:p></span></p><div><p class=MsoNormal><span style='color:#1F497D;mso-fareast-language:EN-AU'>Kind Regards,<o:p>" + Signature;>
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Jose C Gomez
T: 904.469.1524 mobile
On Tue, Oct 1, 2013 at 12:27 PM, <ralmon@...> wrote:Â<div> <p></p><p>I'm not having a logon issue yet...I receive the following errors when I post into the Script editor and change all the database locations to our DB name. I have put the 3 DLL files into the client folder on my machine. </p>
What am i doing wrong??
Quis custodiet ipsos custodes?On Mon, Sep 30, 2013 at 12:40 PM, <ralmon@...> wrote:Â<div> <p>Ok, been trying to get this to work for a while now and I can't find the DLL files. I have run searches on my computer and tried to browse to different paths, the only thing i can find are MSIL with these names, and i can't copy these.  So what is the best way move the DLL file into the client folder. </p>
Bobby
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
> Greetings all,
> Here is the code…
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
</div> <div style="color:#fff;"></div>
Hi,
I've been following this thread and our requirement is similar, but to close a Case then email a call closure acknowledgement to the client who raised the case in the first place. I have got is all working, Filesystem watcher. It works ok. The one question I have is that a majority of our users are on Outlook 2003 (don't ask). We get the security warning about another program is attempting to access your address book. You don't get the option to permanently disable the warning! This error message does not occur if you have Outlook 2007.
I have seen a few solutions from using Outlook redemption. Resource Kit Security templates or an Outlook Addin to manage. I am wondering if anyone else has struck this and how they rectified it? I proposing to get our Outlook 2003 clients upgraded, a bit of a sledgehammer approach, but it does get us closer to a more standardized operating environment.
Any feedback appreciated.
Simon Hall
---In vantage@yahoogroups.com, <jose@...> wrote:Ok hopefully this helps
Jose C GomezSoftware Engineer
Quis custodiet ipsos custodes?On Tue, Oct 1, 2013 at 12:27 PM, <ralmon@...> wrote:<div> <p>I'm not having a logon issue yet...I receive the following errors when I post into the Script editor and change all the database locations to our DB name. I have put the 3 DLL files into the client folder on my machine. </p>
Quis custodiet ipsos custodes?On Mon, Sep 30, 2013 at 12:40 PM, <ralmon@...> wrote:<div> <p>Ok, been trying to get this to work for a while now and I can't find the DLL files. I have run searches on my computer and tried to browse to different paths, the only thing i can find are MSIL with these names, and i can't copy these. So what is the best way move the DLL file into the client folder. </p>
Bobby
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
> Greetings all,
> Here is the code…
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
Jose C Gomez
On Thu, Nov 21, 2013 at 8:31 AM, <s1mhall@...> wrote:Â<div> <p></p><p> Hi,</p><p>I've been following this thread and our requirement is similar, but to close a Case then email a call closure acknowledgement to the client who raised the case in the first place. I have got is all working, Filesystem watcher. It works ok. The one question I have is that a majority of our users are on Outlook 2003 (don't ask). We get the security warning about another program is attempting to access your address book. You don't get the option to permanently disable the warning! This error message does not occur if you have Outlook 2007.<br>
Simon Hall
—In vantage@yahoogroups.com, <jose@…> wrote:
Quis custodiet ipsos custodes?On Tue, Oct 1, 2013 at 12:27 PM, <ralmon@...> wrote:Â<div> <p>I'm not having a logon issue yet...I receive the following errors when I post into the Script editor and change all the database locations to our DB name. I have put the 3 DLL files into the client folder on my machine. </p>
Bobby
Here is the code:
using System;
using System.Data;
using System.IO;
public class Script
// The files are:
int PONUM;
string Approved;
return;
bool morepages;
int timer=0;
timer = timer + 1;
if (timer > 30)
return;
string sFilePath;
repDoc.Refresh();
repDoc.Export();
try
> Greetings all,
> Here is the code…
> int PONUM;
> string Approved;
> return;
> bool morepages;
> repDoc.Refresh();
> try
> oRecip.Resolve();
> //Clean up
> oRecips = null;
> oRecip = null;
> oMsg = null;
> oApp = null;
> else
