Creating a record in UD20, outside of Epicor with BO's
Hi all,
I was tasked with a project needing to write data into our Epicor DB from another tool we created in VS c#. In order to do that I intend to modify the tool to create records in the UD20 table using Epicor BO’s.
What reference are needed to add to the project?
What are the steps / syntax needed if I want to use the BO ?
Pierre
You can use REST to create those records. Either use the BO’s directly, or create a UBAQ and call it using REST.
