There is a "Required" checkbox in Extended Properties maintenance. From
what I can tell, this does not make the field required when saving. But if
you go to Tools | Options | Control Indicators and check the "Required
Field" checkbox and choose a color, all the fields that are marked as
"Required" in Extended Properties will have that different color border.
Even UD fields.
Scott
On Tue, Apr 9, 2013 at 2:55 PM, Joshua Giese <jgiese@...
Even UD fields.
Scott
> wrote:[Non-text portions of this message have been removed]
> It's a property provided by infragistics. If you look at the properties
> panel while focused on a textbox field you will see the property for border
> color. Just modify the color in your code when x conditions are met.
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "Jose Gomez" <jose@...>
> To: "Vantage" <vantage@yahoogroups.com>
> Sent: Tuesday, April 9, 2013 2:51:53 PM
> Subject: Re: [Vantage] Re: creating Required field color
> Epicor 9.05 already has this fucntio you just have to enabled it, in the
> Options
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Tue, Apr 9, 2013 at 3:50 PM, noor.fazli@...
> <noor.fazli@...>wrote:
> > I'm looking for some way to Programmatically set the border color of
> > Epitextbox and Epicombobox to red in C#. This is done to make sure that
> the
> > fields with red border are one of the required fields and as soon as the
> > field gets the value we want to make the borderColor turn to normal.
> > --- In vantage@yahoogroups.com, "noor.fazli@..." <noor.fazli@...>
> wrote:
> > > Hi,
> > > Is it possible to make custom mandatory fields to be displayed in the
> > different color. If it is how can I make sure that the all the custom
> > fileds are displayed in red while adding data.
> > > thanks
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
