We are looking at implementing Epicors CC Module and EPX to improve the overall flow of CCs Quote-to-Cash and improve PCI compliance. However, I have a few related questions.
Is anyone using them? If so, what are your thoughts? Pros / Cons
Is Professional Sevices required to install, configure and train? Or can it be done internally?
Yes, works fine , integrates great is easy to use. It “just works”
No, you can do it its pretty trivial. Just intall the CR software, configure it and #MoveOn there isn’t a lot of configuration all of it is done inside Epicor.
The only complaint I’ve heard is that there is only one token per customer. So if you have a customer with multiple buyers that each have a different CC# then you have to take the number each time. At least that was true a year ago.
