Credit Cards Not processing after going to VM
We went virtual and we have 2 virtual machines, for now. One of them is the SQL/E10 and the other is the Application/Task Agent. After migrating my shippers over, it became apparent that none of the credit cards would work. Anyone else face this?
What processor do you use? If you use CRE you will need to install CRE and then update the IP of the CRE agent in Credit Card Config.
If you have CRE, you should also copy your program directories over otherwise you will get some PNRef issues.
@chaddb @Doug.C I just opened up the Credit Card Config and noticed we do not have a processor name listed or an Gateway specified. It works in our old live setup, and I do know we use a third party processor that connects through Paypal.
Copy the gateway and processor info from your old environment into your new environment.
Yeah, its already there.
