I am facing an issue when I do a paste insert or paste update in the job entry screen for the Crew Size field. When I do a paste (insert or update), it initially seems like the field is taking the values I have defined for crew size, but then it defaults to a crew size of 1 for all the lines regardless of what I am pasting. I have tried to find some solution online but to no avail. Has anyone encountered this issue before? I am not sure if I am missing something. Is there a way to fix this or manual updation for each individual operation is the only way for this? Thanks for your help!
I think the crew size is being defaulted from the operation. you could try setting the override rates and then you could also have to set the labor and burden rates.
Another approach would be to bring in crew size in another field and use a bpm to reset it after it was on the job.
