Cross-site Trackers
Some processes are very site specific. If you launch the Customer Shipment Tracker from Site ‘A’, on shipments made from Site ‘A’ are retrievable.
Any way to allow trackers to not be limited to the site that the tracker was launched from?
This also causes problems if trying to open a tracker from a Dashboard (which can see across all sites), using the right-click “Open with”.
For example, A dashboard shows all shipments. But I can only use the “Open with … Tracker” on shipments made from the site the Dashboard was launched from. The worst part is, is that it does launch the tracker, but then says “The record does not exist”, often misleading people into thinking the related record got deleted somehow.
Any way around this?
