CRW32.EXE Error using Crystal
We're just glad it's working. This has been a full week's project
and while we might not fully understand the "whys" the one thing
we've all learned is, "whatever works". Thanks so much, as always,
for responding. I really appreciate it. Some day we'll get all of
our computers properly upgraded!
Judy H
Plitek
--- In vantage@yahoogroups.com, "Troy Funte" <tfunte@e...> wrote:
> Crystal 8.0 and 8.5 have some new features with date ranges in
parameters, plus some new commands with dates. It sounds like a
version conflict between the two. As you found out, you need to use
the command that works for both (ie. 7.0). Also, perhaps 8.5 isn't
saving in the 7.0 format accurately.
> Troy Funte
> Liberty Electronics
> From: Judy Havlik <judy.havlik@p...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, January 29, 2003 3:59 PM
> Subject: [Vantage] Re: CRW32.EXE Error using Crystal
> I have Crystal 7.0 on my computer but one of the other computers
has,
> I believe, 8.5? The message was the same on both. What I found
is
> that you can't use "between", however, when I changed my formula
to
> {ShipHead.ShipDate} > Date (2002, 06, 01) and {ShipHead.ShipDate}
> Date (2002, 06, 30) it worked fine.
> > Which version of Crystal? Also, are you using Web Component,
> Compiled reports, or Crystal Designer to view the report?
> > Troy Funte
> > Liberty Electronics
> > Sent: Wednesday, January 29, 2003 3:08 PM
> > Subject: [Vantage] CRW32.EXE Error using Crystal
> > We have an ODBC Crystal report that we're trying to run. If
we
> > select one date, the preview of the report works fine. If we
> select
> > a date range, the report cancels and we get a CRW32.EXE error.
> > Does anyone have any ideas?
> > Sincerely,
> > Judy Havlik
> > Plitek, L.L.C.
> > 847-827-6680 x223
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must have already linked your email address to a yahoo id to
enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services
goto:
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
must have already linked your email address to a yahoo id to enable
access. )
Service.
We have an ODBC Crystal report that we're trying to run. If we
select one date, the preview of the report works fine. If we select
Sincerely,
Judy Havlik
Plitek, L.L.C.
847-827-6680 x223
Which version of Crystal? Also, are you using Web Component, Compiled reports, or Crystal Designer to view the report?
Troy Funte
Liberty Electronics
Sincerely,
Judy Havlik
Plitek, L.L.C.
847-827-6680 x223
I have Crystal 7.0 on my computer but one of the other computers has,
I believe, 8.5? The message was the same on both. What I found is
that you can't use "between", however, when I changed my formula to
{ShipHead.ShipDate} > Date (2002, 06, 01) and {ShipHead.ShipDate} <
> Troy Funte
> Liberty Electronics
select
> Sincerely,
> Judy Havlik
> Plitek, L.L.C.
> 847-827-6680 x223
access. )
Service.
Crystal 8.0 and 8.5 have some new features with date ranges in parameters, plus some new commands with dates. It sounds like a version conflict between the two. As you found out, you need to use the command that works for both (ie. 7.0). Also, perhaps 8.5 isn't saving in the 7.0 format accurately.
Troy Funte
Liberty Electronics
> Troy Funte
> Liberty Electronics
select
> Sincerely,
> Judy Havlik
> Plitek, L.L.C.
> 847-827-6680 x223
access. )
Service.
ADVERTISEMENT
