Majority of our reports are custom, and most of them use SQL Server stored procedures as data source.
So, when copying a image of live over to Pilot test server so people can do "break it", I have to manually copy the reports over adn change the data source manually, one by one which is time consuming.
If you've used Crystal 2008, do you know if it can easily handle maintaining multiple copies of same report, only difference being the data source?
Thank you
Thank you
