Crystal 8.5 - Setting paper source
Thanks. As a distributed report I think it will work in 6.1. But I will have to create a distributed version specific to that printer for the one department that needs it. I did a test to one printer specifying the manual feed and it worked. If I make a distribution for each form to a specific tray on the specific printer I can add these as favorites items. The users will print preview the Job Traveler and then print with the special distributed report from their favorites bar.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nigel Kerley
Sent: Wednesday, August 05, 2009 10:41 AM
Subject: [Vantage] Re: Crystal 8.5 - Setting paper source
Hi Todd,
Epicor introduced this into Vantage around 8.03.403. You have to add the "/RPT" argument to the command line when starting Vantage.
I think you're on v6 though(?) and I don't about that version.
In v8, as of SP406a, it still doesn't work properly. There's more fixes scheduled for SP409.
HTH,
Nigel.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Todd Caughey <caugheyt@...> wrote:
> Does Crystal save and obey the printer setup with regard to selecting a specific paper tray when run from Vantage? Does this apply also to distributed reports?
> I have several distributed flavors of the Job Traveler that I would like to force to pull from specific paper trays to select different paper colors or labels depending on the variation being run Has anyone done this?
> I have not purchased the extra paper trays for an HP printer yet and wanted to see if I can make sure this will work before I do. I can maybe try it with the existing manual feed but thought I would ask first.
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
Todd Caughey
Hi Todd,
HTH,
Nigel.
> Thanks,
> Todd Caughey
