Crystal 8.5 text field
Great Mark,
hope it works out.
regards,
Len Holtkamp
Project Manager
Bumet BV
Buijsen Metaalindustrie, Heeze
www.Bumet.nl
Len.Holtkamp@...
> -----Oorspronkelijk bericht-----
> Van: Mark Dupuis [SMTP:dupuism@...]
> Verzonden: dinsdag 27 augustus 2002 16:32
> Aan: vantage@yahoogroups.com
> Onderwerp: RE: [Vantage] Crystal 8.5 text field.
> Len,
> I think you are on to something. The field in question only vanishes when
> I print to an Epson 300 9pin. I printed to three other printers and the
> field prints fine without previewing first. I will call tech support.
> Thanks.
> Mark
> -----Original Message-----
> From: Len Holtkamp [mailto:Len.holtkamp@...]
> Sent: Tuesday, August 27, 2002 10:18 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Crystal 8.5 text field.
> Mark,
> I have had a similar problem, though a little different. If I printed po
> confirmation without preview all worked fine. If I previewed it first, some
> lines had shifted positions, making the last lines fall off. It took me
> quite some time to find the cause of my problem.
> Vantage uses a dll to address our (HP) printers, and this dll was the cause.
> Having our techsupport replace the dll solved the problem.
> Hope this helps,
> regards
> Len Holtkamp
> Project Manager
> Bumet BV
> www.Bumet.nl
> Len.Holtkamp@...
> > Verzonden: dinsdag 27 augustus 2002 15:59
> > Aan: Vantage Users Group
> > Onderwerp: [Vantage] Crystal 8.5 text field.
> > Hello group,
> > I added a text field to the poform for our tax id. When I print the form
> > the field only appears on the printout if I preview it first. Very
> Strange.
> > I am using crystal developer 8.5 and Vantage 5.10.125. Has anyone had
> this
> > problem before?
> > Mark
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > (3) To view links to Vendors that provide Vantage services goto:
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links >
Hello group,
the field only appears on the printout if I preview it first. Very Strange.
I am using crystal developer 8.5 and Vantage 5.10.125. Has anyone had this
problem before?
Mark
Mark,
I have had a similar problem, though a little different. If I printed po confirmation without preview all worked fine. If I previewed it first, some lines had shifted positions, making the last lines fall off. It took me quite some time to find the cause of my problem.
Vantage uses a dll to address our (HP) printers, and this dll was the cause. Having our techsupport replace the dll solved the problem.
Hope this helps,
regards
Len Holtkamp
Project Manager
Bumet BV
www.Bumet.nl
Len.Holtkamp@...
> Hello group,
> problem before?
> Mark
Len,
Thanks.
Mark
Mark,
Hope this helps,
regards
Len Holtkamp
Project Manager
Bumet BV
www.Bumet.nl
Len.Holtkamp@...
> Hello group,
Strange.
this
> problem before?
> Mark
