Crystal Assistance
Your Report Data Def or your BAQ simply do a calculated field that converts
it to an int.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, May 4, 2011 at 4:56 PM, Karl Dash <dashkarl@...> wrote:
> I want to create a Crystal report on open POs that do NOT have their
> quantity
> locked. This, of course, is stored in the COMXref file under field foreign
> Key2.
> The problem is that the PO number on the COMXref is stored as string
> whereas the
> PONum is integer on the POHeader table and Crystal doesn't like
> incompatible
> types being matched. Any thoughts or is the suggestion, "use Access for
> this
> problem".
> Thanks, -Karl
I want to create a Crystal report on open POs that do NOT have their quantity
locked. This, of course, is stored in the COMXref file under field foreign Key2.
The problem is that the PO number on the COMXref is stored as string whereas the
PONum is integer on the POHeader table and Crystal doesn't like incompatible
types being matched. Any thoughts or is the suggestion, "use Access for this
problem".
Thanks, -Karl
