Crystal - Dates (on AP Checks)
Lots of little reasons more than any huge issue.
1. That's what we have always been using (good reason right?)
2. Avoided transferring lots of assets and values
3. FAS is what our auditors use, recommend and most of all understand
4. We don't rely on posting values to G/L since we use a whopping big spreadsheet to consolidate all the various companies under our parent structure
5. Works for assets outside of our Vantage related companies (can you depreciate a race horse?)
6. Comes with updates for asset categorization for tax purposes
7. I think it was less expensive - especially for just one accounting user
That said I have to add that because of these reasons we never really looked at what Epicor has so I have no opinion about their product at all (other than cost).
-Todd C.
Sent: Tuesday, November 23, 2004 12:04 PM
Subject: [Vantage] Re: Crystal - Dates (on AP Checks)
Todd,
Why are you using Best Software's Fixed Asset tool and not Epicor's?
I notice Patrick at Speciality Screw also uses Best's product.
We have recognised a need for some sort of fixed asset management
tool and thought we would look at Epicor's product. Is there
something we should know? I did hear someone say at Perspectives that
the depreciation calculation does not work in the US version but it
does in the European one. Is that the erason? We are in Canada so I'm
not sure how this will affect us - I do know we were misled with the
payroll module and its ended up being shelfware. I'd appreciate any
feedback you have.
Regards,
Dawn
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> Moved our AP person to a new PC and have had no end to problems
with Crystal reports. Mostly due to conflicts with Best Software's
FAS Report Writer which is Crystal based. I have uninstalled the FAS
Report Writer.
> Finally have it all resolved except for one issue with dates. It
has changed to mm/dd/yyyy (4-digit year) format for just her. it
used to be mm/dd/yy on the dates on checks. I could expand the field
sizes but since we have made no other AP Check mods would like to
leave it alone.
> Anyone know why it would switch to 4 digit year and how to set it
back for this user?
> Using Vantage 6.10.
> Any suggesytions for getting FAS and Vantage to play nice with
Crystal would also be appreciated
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=1294ck6ke/M=296572.5585671.6651487.3001176/D=groups/S=1705007183:HM/EXP=1101319483/A=2343726/R=0/SIG=12im32n9e/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1101233083184203> <http://us.ard.yahoo.com/SIG=1294ck6ke/M=296572.5585671.6651487.3001176/D=groups/S=1705007183:HM/EXP=1101319483/A=2343726/R=1/SIG=12im32n9e/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1101233083184203>
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=1101233083184203>
<http://us.adserver.yahoo.com/l?M=296572.5585671.6651487.3001176/D=groups/S=:HM/A=2343726/rand=660003581>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Moved our AP person to a new PC and have had no end to problems with Crystal reports. Mostly due to conflicts with Best Software's FAS Report Writer which is Crystal based. I have uninstalled the FAS Report Writer.
Finally have it all resolved except for one issue with dates. It has changed to mm/dd/yyyy (4-digit year) format for just her. it used to be mm/dd/yy on the dates on checks. I could expand the field sizes but since we have made no other AP Check mods would like to leave it alone.
Anyone know why it would switch to 4 digit year and how to set it back for this user?
Using Vantage 6.10.
Any suggesytions for getting FAS and Vantage to play nice with Crystal would also be appreciated
Todd Caughey
Todd,
The date setting sounds like the client OS, Control Panel / Regional and
Language Options.
We moved Best Software Fix Assets to a PC in the Computer Lab and access it
with XP Remote Desktop. This kept it isolated from Epicor Crystal and since
we only have two people who need it on a limited bases it worked well for
us.
Patrick Winter
Sent: Thursday, November 11, 2004 10:32 AM
Subject: [Vantage] Crystal - Dates (on AP Checks)
this user?
Using Vantage 6.10.
also be appreciated
Todd Caughey
------------------------ Yahoo! Groups Sponsor --------------------~--> Make
a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
Todd,
I bet it is the Regional Settings for the Short Date format for that
PC that is causing the problems. Check it out in the control panel.
Brian Stenglein
Clow Stamping Co.
Report Writer.
leave it alone.
back for this user?
> Using Vantage 6.10.
> Thanks,
> Todd Caughey
Todd,
I ended up putting ABRA (best) on terminal server, and vantage
on the client.
Not a perfect solution, but eliminated my problems.
Brian & Patrick.....look like that's it. Have not tried checks again but the settings were as you both described so I would concur that's likely the issue.
Thanks much!
-Todd
Sent: Thursday, November 11, 2004 10:49 AM
Todd,
Brian Stenglein
Clow Stamping Co.
Report Writer.
leave it alone.
back for this user?
> Using Vantage 6.10.
> Thanks,
> Todd Caughey
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129775bo1/M=298184.5584357.6650215.3001176/D=groups/S=1705007183:HM/EXP=1100278165/A=2426683/R=0/SIG=11eeoolb0/*http://www.netflix.com/Default?mqso=60185400> click here
<http://us.adserver.yahoo.com/l?M=298184.5584357.6650215.3001176/D=groups/S=:HM/A=2426683/rand=785831698>
_____
Yahoo! Groups Links
Todd,
feedback you have.
Regards,
Dawn
Report Writer.
leave it alone.
back for this user?
> Using Vantage 6.10.
> Thanks,
> Todd Caughey
