Hi Brian,
I was in the same boat as you. I use the Crystal Distribution function quite
often and was not happy when I discovered that they had taken this feature away
in version 8.0...which I had purchased.
However, you can still get this function if you go to www.seagatesoftware.com.
Seagate made this feature available again as a free download. They made this
available in response to customers expressing their dismay in the feature going
away. When you download the file, they make you click on a statement basically
saying that "I understand that this is really the last time that this feature
will be available."
If you have not already upgraded to Crystal 8.0 I strongly recommend you also
download the conversion document from the seagate website. I ran into several
conversion problems AFTER I upgraded which are addressed in this document.
Hope this helps.
Mike Lowe
Corporate I.S. Manager
Connor Manufacturing Services
MLowe@...
(909) 273-1282
will be available."
Hope this helps.
Mike Lowe
MLowe@...
(909) 273-1282
