Sure let me know what you need. My address is below.
Ted Kitch
ted@...
Ted Kitch
ted@...
----- Original Message -----
To: vantage@egroups.com
Sent: Wednesday, November 29, 2000 12:27 AM
Subject: Re: [Vantage] Crystal Distribution & OLAP
Ted,
I'd like to be able to contact you off line to ask you some things about the server set up, if possible.
Would you be willing to email me?
Troy Funte
Liberty Electronics
Sent: Friday, November 17, 2000 8:21 PM
I've got it running fine as a service. There could be some permissions that
would have to be set for certain files. Version 7 had some issues with NT
permissions when running as a service. Look for any files on the Seagate KB
that have infinite logon. There are plently of pointers there.
Ted Kitch
tedkitch@...
On Fri, 17 Nov 2000 08:31:17 -0800, vantage@egroups.com wrote:
> Ted,
> Were you able to get Crystal Web Server working on the Vantage Server
as a service? We couldn't get past the login screen when running as a
service. We had to disable the Crystal Web Server in the Services area of NT
(which Crystal said was due to something with progress), then RUN the Web
Server program from a DOS prompt and it runs minimized on the task bar. Is
this the case for you?
> Troy Funte
> Liberty Electronics
> From: Ted Kitch
> Sent: Thursday, November 16, 2000 9:37 PM
> I've got the Crystal Web Components running fine on a Vantage server.
I
> don't know why Epicor would come out and say that they don't recommend
it.
> It works great. Crystal 8 offers many more options than 7 for
distributing
> reports. Feel free to contact me offline for any info.
> Ted Kitch
> tedkitch@...
> On Wed, 15 Nov 2000 08:26:38 -0800, vantage@egroups.com wrote:
> > Brian,
> > Crystal 8 does provide a download to install the Distribution
Expert
> from their WebSite. I have installed it, but I haven't actually used
it
> yet. The buttons for distribution are the same as in Crystal 7.
> > The Crystal Web Component is pretty exciting to me. The downside is
you
> have to have it installed on a server. I have successfully got it
running
> on the Vantage server, but Epicor does not recommend this, and you have
to
> tweek a bunch of things. That said, if you had an NT server running
> separate from Vantage with the Web Server Component these are the
> advantages:
> > 1. A workstation only needs IE 3 or Netscape 3 to run the report.
> > 2. A workstation does NOT need the ODBC drivers to run the report.
All
> the data is accessed from the Server (which DOES need ODBC). Thus, one
copy
> of Merant 3.5 ODBC drivers are needed instead of countless numbers.
(except
> if you already have the drivers this won't be an advantage).
> > 3. A report run via Web Server retains the "Tree View" that you get
to
> use when Designing a report. A user can click on a group on the left
and go
> right to it in the report.
> > A Note: I do like working with Crystal 8 slightly better than
Crystal 7
> for designing reports, but it won't be worth it to you to change "just"
for
> report design benefits. I do believe overall it has been a worthwhile
> purchase for us at Liberty.
> > Hope this helps with your decision.
> > Troy Funte
> > Liberty Electronics
> > From: Brian Stenglein
> > Sent: Monday, November 13, 2000 10:15 AM
> > Subject: [Vantage] Crystal Distribution & OLAP
> > My company is still in testing, but I am beginning to produce a
> > number of reports for various departments. I am trying to decide
how
> > best to distribute them. With Crystal 7, there is a distribution
> > expert that is pretty handy, but they do away with that in Crystal
> > 8. I was really considering upgrading to Crystal 8, (I've
installed
> > it on one machine for testing), until I learned that there is no
> > distribution expert.
> > They recommend using a Windows application like Visual Basic, or a
> > Crystal Web Component Server instead of the executable created by
the
> > distribution expert. I know a little VB so I created a quick app.
to
> > test launching one report from it. It does work, although I don't
> > see any real advantages over the distribution expert in version 7,
in
> > fact I think it is more work.
> > I would like to hear how you are using Crystal and how you are
> > distributing reports. Also, I am curious about using OLAP. Is
> > anyone using this, is it possible with Progress, how does one get
> > started with OLAP?
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
> > eGroups Sponsor
> > We no longer allow attachments to files. To access/share Report
Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try
it,
> go to www.egroups.com, login and be sure to save your password, choose
My
> Groups, choose Vantage, then choose Files. If you save the password,
the
> link above will work the next time you try it.)
> Ted Kitch
> tedkitch@...
> _______________________________________________________
> Tired of slow Internet? Get @Home Broadband Internet
> http://www.home.com/xinbox/signup.html
> eGroups Sponsor
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it,
go to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
Ted Kitch
tedkitch@...
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
eGroups Sponsor
