Mark,
In your simplified example, all you need to do is use a record selection
formula that says:
isnull({LaborDtl.JobNum})
This will give you only the records in the JobHead where the LaborDtl does
NOT have a corresponding record.
Troy Funte
Sent: Friday, June 06, 2003 10:17 AM
To: Vantage Users Group (E-mail)
Subject: [Vantage] crystal filter
Hello group,
It's been a while since I've had to bug you guys but I'm kind of
stuck on
this one. I have a rather complex report in crystal with 9 or 10 tables
and
4 sub reports so I'm going to use a simple example to explain my problem.
If you left outer join the JobHead and LaborDtl tables using the JobNum
field you get a data set. Some records in this set may or may not have
labor
details. I would like to use a filter to see only records that have no
labor details. Is there a way to use a filter to do this?
Mark Dupuis
Yahoo! Groups Sponsor
formula that says:
Troy Funte
Hello group,
stuck on
and
labor
Mark Dupuis
