Crystal formula help
Aha! How about:
nextdate = datevalue(nextvalue({BAQReportResult.LaborHed.ClockInDate}))
Of Dan Shallbetter
Sent: Friday, November 30, 2007 8:21 AM
Subject: RE: [Vantage] Crystal formula help
Hello Ken,
The NextValue function returns the value of the next record of the
specified field. This reports was done years ago back when I could
remember things! I think the formula came from another user in this
group. I too normally use Crystal syntax
Dan
Behalf
Of Ken Williams
Sent: Friday, November 30, 2007 8:36 AM
I can't tell you what may have changed as I started on 8.00. In
addition, I've only really dived heavily into Crystal the last few
months from .305 & .403. Going further, I do all my Crystal programming
in Crystal Syntax, not Basic, so there's anther barrier there. Lastly,
I haven't used the nextvalue function before and crystal help isn't
exactly clear on what it does.
All that being said, if what you did were done with Crystal equivalents,
I can't see anything wrong with the syntax. What does the nextvalue
function do exactly?
Behalf
Of Dan Shallbetter
Sent: Friday, November 30, 2007 7:22 AM
Subject: [Vantage] Crystal formula help
Hello Ken,
Thanks for the reply. I am trying to convert a Vantage 5.0 weekly
attendance (feeds ADP) report into my test 8. 0403C environment. The
data dictionary display a field type of "DATE" for Laborhed.ClockInDate
Crystal calls it a "date/time" field. Did the BAQ change the field type?
Applying the same date conversion to the nextdate variable as I used in
thisdate it errors out and wants a field after the nextvalue function.
This formula is the problem.
Vantage 8.0.4023
dim thisdate as date
dim nextdate as date
dim output as string
thisdate = datevalue({BAQReportResult.LaborHed.ClockInDate})+ 1
nextdate = nextvalue (datevalue({BAQReportResult.LaborHed.ClockInDate}))
Original line nextdate = nextvalue({LaborHed.ClockInDate})
do while nextdate - thisdate > 0
output = output + totext(thisdate, "MM/dd/yy") + chr(10)
thisdate = thisdate + 1
loop
formula = output
Dan
Behalf
Of Ken Williams
Sent: Thursday, November 29, 2007 4:17 PM
I use the date() function from Crystal for these situations:
thisdate = date({BAQReportResult.LaborHed.ClockInDate}) + 1
Ken
Behalf
Of Dan Shallbetter
Sent: Thursday, November 29, 2007 3:12 PM
I am converting an old ODBC data source report (Crystal 8.5) to an XML
data source (Crystal XI) report the following formula returns a Date
field required here error
thisdate = {BAQReportResult.LaborHed.ClockInDate}+ 1 This formula
worked previously checking the field type for
BAQReportResult.LaborHed.ClockInDate shows it as a Date / time field
Any ideas?
Dan Shallbetter
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msg
Id=60976/stime=1196374516/nc1=4507179/nc2=4706133/nc3=5008825>
Any ideas?
Dan Shallbetter
Ken
Of Dan Shallbetter
Any ideas?
Dan Shallbetter
Hello Ken,
Vantage 8.0.4023
loop
formula = output
Dan
Of Ken Williams
Ken
Behalf
Of Dan Shallbetter
Any ideas?
Dan Shallbetter
Of Dan Shallbetter
Hello Ken,
Vantage 8.0.4023
loop
formula = output
Dan
Behalf
Of Ken Williams
Ken
Behalf
Of Dan Shallbetter
Any ideas?
Dan Shallbetter
Hello Ken,
Dan
Of Ken Williams
Behalf
Of Dan Shallbetter
Hello Ken,
Vantage 8.0.4023
loop
formula = output
Dan
Behalf
Of Ken Williams
Ken
Behalf
Of Dan Shallbetter
Any ideas?
Dan Shallbetter
