Crystal Help
just a thought if you dont get a response from this group go to:
http://groups.yahoo.com/group/crystalreportsusersgroup/ would be the
a specific domain for ur query.
--- In vantage@yahoogroups.com, "Chris Crosta" <chris@...> wrote:
> Can anyone tell me how to select only the most recent transaction
record
> for an operation. I have a sub report that lists every operation
a job
> will go through with a formula field that gives the status of the
> operation.
> if {LaborDtl.ActiveTrans}=True
> Then "In Progress" & "-" & Totext({LaborDtl.ClockInDate}&"
> "&{LaborDtl.ClockinTime}&" "&{EmpBasic.Name})
> Else if {LaborDtl.ActiveTrans}=False
> Then "Work Stopped"& "-" & totext({LaborDtl.ClockInDate}&"
> "&{LaborDtl.ClockOutTime}&" "&{EmpBasic.Name})
> Else ""
> Problem is that when my operators don't complete the operation on
the
> first clock in I end up with multiple transactions showing up for
each
> operation and I only need to see the most recent for each
operation.
> Thanks,
> Chris
Maybe if you group your detail from Insert/Group... then set your
formula from there. Hope it helps in some way.
record
a job
> operation.
> Else ""
the
each
operation.
> Thanks,
> Chris
Maybe I am underthinking this, but I believe you could set a group based
on the operation, suppress the details, set a condition in your
if-then-else to test for the most recent transaction, and execute.
So basically;
if {LaborDtl.ActiveTrans, maxtrandate} = True then..
Else {LaborDtl.ActiveTrans, maxtrandate} = false then..
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Chris Crosta
Sent: Tuesday, February 14, 2006 7:07 PM
Subject: [Vantage] Crystal Help
Can anyone tell me how to select only the most recent transaction record
for an operation. I have a sub report that lists every operation a job
operation.
Else ""
Problem is that when my operators don't complete the operation on the
first clock in I end up with multiple transactions showing up for each
operation and I only need to see the most recent for each operation.
Chris
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
I believe if you group by operation, then Date descending, then Time
descending and suppress detail. Any detail fields that you drag into
the Time group header section will be the last record (descending Sort).
Any detail fields that you drag into the Time group footer section will
be the first record (descending Sort). This is reversed if the time
sort is ascending.
Hope this helps.
Dale E. Schuerman
Senior Consultant
RAM Software Systems, Inc.
Of Bruce Butler
Sent: Wednesday, February 15, 2006 12:05 PM
Subject: RE: [Vantage] Crystal Help
So basically;
Bruce Butler
IT Manager
_____
Of Chris Crosta
operation.
Else ""
Chris
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
LaborDtl.ClockInMinute contains minutes past base date, so this alone will
sort date and time.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Dale Schuerman
Sent: Wednesday, February 15, 2006 1:37 PM
sort is ascending.
Hope this helps.
Dale E. Schuerman
Senior Consultant
Of Bruce Butler
So basically;
Bruce Butler
IT Manager
_____
Of Chris Crosta
operation.
Else ""
Chris
Attention:
by MailMarshal SMTP
Yahoo! Groups Links
Dale,
Thank you very much that worked out great.
_____
Of Dale Schuerman
Sent: Wednesday, February 15, 2006 10:37 AM
sort is ascending.
Hope this helps.
Dale E. Schuerman
Senior Consultant
Of Bruce Butler
So basically;
Bruce Butler
IT Manager
_____
Of Chris Crosta
operation.
Else ""
Chris
Attention:
by MailMarshal SMTP
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Try this, from Crystal website:
Displaying only the record with the closest date to a parameter, for
each group
http://support.businessobjects.com/library/kbase/articles/c2005926.asp
Joe
record
job
> operation.
> Else ""
the
each
> Thanks,
> Chris
