Charlie's suggestion to use parens to create a multi-function "then"
statement was right on the money! Worked like a charm!
Thanks again, Charlie!
--Ari
Of Ari Footlik
Sent: Thursday, April 02, 2009 10:38 AM
Subject: RE: [Vantage] Crystal Multi-Line "THEN" statements
Linda -
I was trying really hard to avoid switching to Basic Syntax. I'm going
to try Charlie's idea of using parens, but otherwise, I guess Basic
Syntax it will have to be...
Thanks!
--Ari
Behalf
Of Linda Lowney
Sent: Thursday, April 02, 2009 9:42 AM
Hi Rob,
When you create the formula switch it from Crystal syntax to Basic
syntax and it will work better. You can do:
if a = 1 then
b = 2
c = 3
d = 4
else if a = z then
e = 5
f = 6
else
g = 7
h = 8
end if
end if
Don't forget the second end if.
Linda
Behalf
Of Ari Footlik
Sent: Thursday, April 02, 2009 10:34 AM
Rob -
Thanks, but that's not exactly what I'm looking for. "Nested if's" I
could handle. What I really want is a way to perform multiple
operations if a condition is met:
if a = 1 then
b = 2
c = 3
d = 4
else if a = z then
e = 5
f = 6
else
g = 7
h = 8
end if
That's more like what I'm hoping to do.
Behalf
Of Rob Bucek
Sent: Wednesday, April 01, 2009 5:12 PM
Heres actually a better example; this was a calculated field in a BAQ
that I wrote...
if labordtl.labortype="I" then
if labordtl.indirectcode="PMB" then 0 else
if labordtl.indirectcode="STB" then 0 else labordtl.laborhrs
else 0
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> <http://www.dsmfg.com/
<http://www.dsmfg.com/> > <http://www.dsmfg.com/ <http://www.dsmfg.com/>
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > > >
(Click the logo to view our site)
Behalf
Of Ari Footlik
Sent: Wednesday, April 01, 2009 4:14 PM
Subject: [Vantage] Crystal Multi-Line "THEN" statements
Is it possible to put a multiple-line "THEN" statement into a Crystal
Syntax formula?
In v8 we have a user-defined "time" field that is set to be entered as a
string. In CR, I want to convert it into MINS:SECS. So, the first
thing I do is figure out if it's already set as time. To do that, I
have this formula:
local stringVar myTimeS;
//if value is already time, return the value
if (":" in {JobOper.Character02}) then
myTimeS := {JobOper.Character02}
//if value is a decimal, do <something>
else if ("." in {JobOper.Character02}) then
myTimeS := "D"
//if value is an integer, append ":00"
else
myTimeS := {JobOper.Character02} & ":00";
myTimeS := myTimeS;
For the "then" In the "else if" statement, I want to perform more
processing on the value. Is there any way to do that?
Thanks!
--Ari
--Ari
Of Ari Footlik
Linda -
Thanks!
--Ari
Behalf
Of Linda Lowney
Hi Rob,
if a = 1 then
b = 2
c = 3
d = 4
else if a = z then
e = 5
f = 6
else
g = 7
h = 8
end if
end if
Linda
Behalf
Of Ari Footlik
Rob -
if a = 1 then
b = 2
c = 3
d = 4
else if a = z then
e = 5
f = 6
else
g = 7
h = 8
end if
Behalf
Of Rob Bucek
that I wrote...
else 0
Rob Bucek
FAX: 715-284-4084
Behalf
Of Ari Footlik
Syntax formula?
have this formula:
myTimeS := "D"
else
myTimeS := myTimeS;
Thanks!
--Ari
