Crystal Multiple Values
Just glad it worked out for you!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Michael McWilliams
Sent: Friday, September 21, 2007 3:26 PM
Subject: [Vantage] Re: Crystal Multiple Values
Thanks, you were correct I was thinking completely wrong.
"Manasa Reddy" <manasa@...> wrote:
> CALL ME...you can set it up the way you are asking!!
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Sent: Friday, September 21, 2007 3:17 PM
> I understand that part of it. But when the prompt comes up, the
> user gets a list at the left for them to choose from, and then
they
> add it by clicking the arrow to move it to the right. I would like
> for them to type in the value and then add it to the list. I would
> create 10 parameters and then say select where job is equal to any
> one of the parameters. But again it gives a drop down and does not
> allow you to type in any number.
> I appreciate you trying to help.
> "Manasa Reddy" <manasa@> wrote:
> > If you look at your parameter, where you set one up, at the
bottom
> there
> > is a Value options. In here there is an allow multiple values
> option,
> > set it to true.
> > Is this what you are looking for?
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
<mailto:vantage%
> Behalf
> > Sent: Friday, September 21, 2007 3:04 PM
> > Maybe I did not phrase correctly. The list of available values
> > comes from the DB and is updated every time a new job is
created.
> > The static only allows me to predifene values for the report.
> > > Correct, then the static one allows you to input a value.
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
<mailto:vantage%
40yahoogroups.com>
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> > Behalf
> > > Sent: Friday, September 21, 2007 2:53 PM
> > > It is dynamic, but the problem that I am having is I want them
> to
> > > scan or type in the value they want( Not select it from a list
> of
> > > values.
<mailto:vantage%
40yahoogroups.com>
> > > > It's possible...when you create your parameter field, it is
> > either
> > > > dynamic or static....I always forget which but I am leaning
> > against
> > > > static.
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
> > <mailto:vantage%
> > > Behalf
> > > > Sent: Friday, September 21, 2007 2:37 PM
<mailto:vantage%
40yahoogroups.com>
> > > > Subject: [Vantage] Crystal Multiple Values
> > > > I am trying to create a prompt that allows for you to input
> > > multiple
> > > > values but not select from a list using dynamic values. I
know
> I
> > > can
> > > > have them select each one from the scroll list, but that
does
> > not
> > > seem
> > > > feasable when there might be 20k+ values and they will have
to
> > > grab
> > > > from all ends of it. Am I missing something, or is this not
> > > possible
> > > > to do with crystal?
> > > > [Non-text portions of this message have been removed]
I am trying to create a prompt that allows for you to input multiple
values but not select from a list using dynamic values. I know I can
have them select each one from the scroll list, but that does not seem
feasable when there might be 20k+ values and they will have to grab
from all ends of it. Am I missing something, or is this not possible
to do with crystal?
It's possible...when you create your parameter field, it is either
dynamic or static....I always forget which but I am leaning against
static.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
to do with crystal?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
It is dynamic, but the problem that I am having is I want them to
scan or type in the value they want( Not select it from a list of
values.
> static.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
multiple
can
seem
grab
possible
> to do with crystal?
If you want, call me and I will walk you through it...easy to set up.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
values.
> static.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
multiple
can
seem
grab
possible
> to do with crystal?
comes from the DB and is updated every time a new job is created.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> values.
either
against
> > static.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> Behalf
> multiple
> can
not
> seem
> grab
> possible
> > to do with crystal?
So you want to be able to say give me info on Job blahblah, where you
enter blahblah, correct?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> values.
either
against
> > static.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
<mailto:vantage%
> Behalf
> multiple
> can
not
> seem
> grab
> possible
> > to do with crystal?
If you look at your parameter, where you set one up, at the bottom there
is a Value options. In here there is an allow multiple values option,
set it to true.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> values.
either
against
> > static.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
<mailto:vantage%
> Behalf
> multiple
> can
not
> seem
> grab
> possible
> > to do with crystal?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
user gets a list at the left for them to choose from, and then they
there
option,
> set it to true.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
<mailto:vantage%
> Behalf
to
of
> > values.
> either
> against
> > > static.
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
<mailto:vantage%
40yahoogroups.com>
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> > Behalf
> > multiple
I
> > can
> not
> > seem
> > grab
> > possible
> > > to do with crystal?
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
they
bottom
> there
> option,
> > set it to true.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> Behalf
created.
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
40yahoogroups.com>
40yahoogroups.com>
> <mailto:vantage%
> > Behalf
> to
> of
> > > values.
40yahoogroups.com>
> > either
> > against
> > > > static.
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
> > <mailto:vantage%
> > > Behalf
40yahoogroups.com>
> > > multiple
know
> I
> > > can
does
> > not
> > > seem
to
> > > grab
> > > possible
> > > > to do with crystal?
