I've used Crystal for years and as late as Version 7, the standard edition
could be made to connect to an ODBC driver, so I assumed that this was true
with version 8, but apparently I was wrong. So, I looked on the Seagate
Software web site and the standard edition doesn't connect to some ODBC
sources. This is new to me. Here is the URL so you can check
http://www.seagatesoftware.com/products/crystalreports/editions/content.asp
Let me know if you need anymore help,
Ted Kitch
tedkitch@...
Ted Kitch
tedkitch@...
On Thu, 21 Sep 2000 13:10:37 -0000, vantage@egroups.com wrote:
> In that case can anyone explain why the following error occurred when I
> tried to create a new Custom Report using the SQL/ODBC. I selected the
> ODBC - Progress Remote OID and having said OK to the Logon to Progress
> the following message appeared:
> Seagate Crystal Reports: Database Error
> Can not connect to this Data Source. This is the Crystal Reports
> Standard edition. Please upgrade to Crystal reports Pro in order to
> connect to it.
> The ODBC says the Connection has been established!
> Sophie
> -----Original Message-----
> From: Ted Kitch [SMTP:tedkitch@...]
> Sent: Thursday, September 21, 2000 5:01 AM
> To: vantage@egroups.com
> Subject: Re: [Vantage] Crystal & ODBC
> http://click.egroups.com/1/8985/13/_/411782/_/969537668/
> http://adimg.egroups.com/img/8985/13/_/411782/_/969537668/WarningMovies4
> eGroups My Groups <http://www.egroups.com/mygroups> | vantage
> Main Page <http://www.egroups.com/group/vantage> | Start a new group!
> <http://click.egroups.com/1/8150/13/_/411782/_/969537668/>
> It isn't necessary to have Crystal Professional when connecting
> to Vantage
> via ODBC.? The standard product will work fine.? However, for
> the slight
> increase in price I would buy the professional version.? It has
> lots of
> great features, that even though you may not use them today,
> they will help
> out in the future.
> Ted Kitch
> On Thu, 21 Sep 2000 11:17:17 -0000, vantage@egroups.com wrote:
> >? Can anyone confirm whether it is necessary to have Crystal
> Professional
> >? when connecting to Vantage via the ODBC.
> >? Also those of you who have upgraded from Version 7 to 8, do
> any changes
> >? need to be made to existing Crystal reports supplied with
> Vantage?
> >? Thanks in advance,
> >? Sophie
> _______________________________________________________
> Say Bye to Slow Internet!
> http://www.home.com/xinbox/signup.html
> We no longer allow attachments to files.? To access/share Report
> Files, please go to the following link:?
> http://www.egroups.com/files/vantage/
> (Note:? If this link does not work for you the first time you
> try it, go to www.egroups.com, login and be sure to save your password,
> choose My Groups, choose Vantage, then choose Files.? If you save the
> password, the link above will work the next time you try it.)
Ted Kitch
tedkitch@...
