Hi Ken:
Did you receive the file with the detailed BAQ Report information
that I sent you off thread?
Lynn
Lynn
--- In vantage@yahoogroups.com, Ken Taylor <ktaylorv@...> wrote:
> Lynn, the link does not work. Please send me a copy off-thread.
Many thanks.
> ----- Original Message ----
> From: Lynn <lynn.khalife@...>
> To: vantage@yahoogroups.com
> Sent: Monday, September 22, 2008 10:07:11 AM
> Subject: [Vantage] Re: Crystal or Vantage?
> After logging on to the Epicor site with your username & password,
> try pasting the path below into your address bar.
> I do not know how to find AnswerBooks in the menu. I always use
the
> Search command on the Epicor site to find AnswerBooks.
> https://epicweb. epicor.com/ ReportServer/ Pages/ReportView
er.aspx?/ ePort
> al/ABDetail& rs:Command= Render&rc: Toolbar=true& Card_ID=7905MPS&
Answerbo
> ok=Clientele+ Change+Requests
> If you can't find it, I can send you a copy off-thread.
> Lynn
> --- In vantage@yahoogroups .com, Ken Taylor <ktaylorv@ .> wrote:
> > Lynn, do you have the link for #7905MPS?
> > Thanks for your help.
> > ____________ _________ _________ __
> > From: Lynn <lynn.khalife@ ...>
> > To: vantage@yahoogroups .com
> > Sent: Monday, September 22, 2008 9:26:04 AM
> > There are detailed instructions for the steps Vic lists on the
> Epicor
> > website in AnswerBook # 7905MPS, "BAQ Instructions for creating a
> > Crystal Report from a BAQ in BAQ Report Designer"
> > Lynn
> > --- In vantage@yahoogroups .com, "Vic Drecchio"
<vic.drecchio@ ...>
> > wrote:
> > > Ken,
> > > Unfortunately, you cannot modify system default Report Data
> > Definitions.
> > > You would need to make a copy of that respective RDD and then
make
> > > modifications to that definition and then create a new Report
> Style
> > > linking that form to your modified RDD.
> > > However, that being said, what you want to accomplish isn't as
> easy
> > as
> > > it may seem and modifying the Report Data Definition isn't the
> > correct
> > > approach.
> > > To pull Sales Order Ack info for a specific salesperson within a
> > > specific timeframe will require you to create a new report.
> Create
> > a
> > > new BAQ Query and BAQ Report and use filters and option fields
in
> > the
> > > BAQ Report to limit the results as you desire. Create a new
> Crystal
> > > Report mimicking the format of your current Sales Order Ack and
> > using
> > > the result set returned by your BAQ Report. Note: Trying to
use
> > > Vantage's default Sales Order Ack form and tailoring it to your
> new
> > BAQ
> > > will not be impossible, but *very* painful and more time
> consuming
> > then
> > > just re-creating it. Then, once you're comfortable with your
new
> > BAQ
> > > Report, hang it off the menu anywhere you desire.
> > > Good luck.
> > > Vic Drecchio
> > > ERP Administrator
> > > TIMCO Aviation Services
> > > Greensboro, NC
> > > Email: vic.drecchio@ ...
> > > Office: 336.668.4410 x3091
> > > Mobile: 704.530.3092
> > > -----Original Message-----
> > > From: vantage@yahoogroups .com [mailto:vantage@
yahoogroups .com]
> On
> > Behalf
> > > Of Ken Taylor
> > > Sent: Monday, September 22, 2008 11:26 AM
> > > Subject: [Vantage] Crystal or Vantage?
> > > Running Vantage 803.305L
> > > I need to create the standard Order Acknowledgement pulling all
> > orders
> > > with specific salesperson. Tried to add a criteria in the Data
> > > definition, but it will not allow me to do that. I can add the
> > parameter
> > > in the Crystal report, but it will not return any data since
the
> > data is
> > > based on another xml format. Not sure how I can have Vantage
> prompt
> > me
> > > so that I can get all orders with specific salesperson id. This
> is a
> > > report that I need to add as a menu item for others to run.
> > > Any help you provide is greatly appreciated.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> > must
> > > have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups. yahoo.com/ group/vantage/ files/.
> > > (2) To search through old msg's goto:
> > > http://groups. yahoo.com/ group/vantage/ messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups
Links
