Crystal (Payroll Date = Today) help
Just curious,
Why don't you also automatically select the appropriate shift when the
report is run, based on the time of day the report is being run?
selection Formula:
If (Hour(CurrnetTime)*60+Minute(CurrentTime)) < 1stShiftStartMinute Then
{LaborHead.Shift}=3
else (If (Hour(CurrnetTime)*60+Minute(CurrentTime)) <
2ndShiftStartMinute Then
{LaborHead.Shift}=1
3rdShiftStartMinute Then
{LaborHead.Shift}=2
else ({LaborHead.Shift}=3)))
Add more if-else statements for more shifts. Place this in your
Selection Criteria formula window, under the LaborHead.Shift field
formula. Be sure to calculate the cutoff points beforehand for your
appropriate shift start points (i.e. 1st Shift starts @ 6AM, so
1stShiftStartMinute=360). Be sure to keep a copy of the manual
filter/select report on hand for when someone needs to run the report
outside of the date/time range.
Andrew
Of Brian Stenglein
Sent: Friday, April 07, 2006 11:04 AM
Subject: [Vantage] Re: Crystal (Payroll Date = Today) help
Kelly,
The Crystal Function you are looking for is simply CurrentDate.
So your selection statement would be something like
{laborhead.payrolldate}=CurrentDate.
When using the Select Expert you'll need to click the Show Formula
button, then click the Formula Editor Button, then enter the
statement above.
HTH,
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Kelly Wendorff" <kelly.wendorff@...>
wrote:
> Hello,
> I'm trying to write a labor edit report that our shop foreman would
run
> at the end of each shift (through distribution export in 8.5). The
only
> filter that I want to make them change is the shift. I'd like to
have
> the report automatically select the current date and use that for
the
> payroll date.
> I think this is possible but I'm not sure how to accomplish this.
> Any suggestions?
> Thanks,
> Kelly
> Kelly Wendorff
> Cost Accounting Manager
> SteelCraft Corporation
> www.scc-wi.com
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Hello,
I'm trying to write a labor edit report that our shop foreman would run
at the end of each shift (through distribution export in 8.5). The only
filter that I want to make them change is the shift. I'd like to have
the report automatically select the current date and use that for the
payroll date.
Any suggestions?
Kelly
Kelly Wendorff
www.scc-wi.com
Kelly,
statement above.
HTH,
Brian Stenglein
Clow Stamping Co.
wrote:
> Hello,
run
only
have
the
> payroll date.
> Any suggestions?
> Thanks,
> Kelly
> Kelly Wendorff
> www.scc-wi.com
