Crystal Refresh XML Preview
I am not sure if this is what you are looking for but try the
Business Activity Query. The third tab is "Headings". That lists
the default field labels. You can modify those labels there.
--- In vantage@yahoogroups.com, "laidig.systems"
<laidig.systems@...> wrote:
> That's exactly what i needed. Thanks. As far as the second part
of
> my question. What is the correlation between the labels in Vantage
> and the labels in Crystal. I can't seem to find the labels to
change
> within vantage that will change in Crystal.
> --- In vantage@yahoogroups.com, "al2trace" <allen.larsen@> wrote:
> > Assuming V8.03 and Crystal 11
> > To link to a new XML file after adding fields in Report Data
> > Definitions,
> > 1. In Vantage, create a new "Report Style", specifying the new
> > Report Data Definition and the old Crystal report.
> > 2. In Vantage, print or print-preview the report using the
> > new "Report Style".
> > 3. Open up the report in Crystal and link to the XML that you
> > created. From the Crystal menu, choose "Database", "Set
Database
> > Location...". From the bottom half of the dialog box,
> > expand "Create New Connection", then expand "ADO.NET (XML)".
Click
> > the "...." button next to "File Path:". Choose the XML created
> > above (most recent file date in your reports directory).
> > Highlight "ReportDataSet" in the bottom half of the dialog box.
> > ("ReportDataSet" should have a gray highlight in the top half of
the
> > dialog box. Click the "Update" button. The new fields should
now
> > be in your field explorer under the appropriate table.
> > I focused the detail on step 3 because that seems like the most
> > confusing step. If you need help with any of the other steps, e-
> > mail me direct.
> > Have a nice day.
> > <laidig.systems@> wrote:
> > > I am modifying a sales order report and in Crystal when i do a
> > print
> > > preview, i link my report for previewing to an xml file from a
> > > previously run Sales Order report in Vantage. After i have
> > created
> > > that link to the xml file, i went into Vantage and added some
> > fields in
> > > the Report Data Definitions. How do i link my crystal report
to
> > that
> > > new xml file for previewing?
> > > Another question i have is how do I use the Lables in
Vantage? I
> > don't
> > > see a correlation between the "RptLabels" table in Crystal.
Can
> > > someone explain those to me?
> > > Thanks
I am modifying a sales order report and in Crystal when i do a print
previously run Sales Order report in Vantage. After i have created
that link to the xml file, i went into Vantage and added some fields in
the Report Data Definitions. How do i link my crystal report to that
Another question i have is how do I use the Lables in Vantage? I don't
see a correlation between the "RptLabels" table in Crystal. Can
Definitions,
new "Report Style".
created. From the Crystal menu, choose "Database", "Set Database
expand "Create New Connection", then expand "ADO.NET (XML)". Click
("ReportDataSet" should have a gray highlight in the top half of the
dialog box. Click the "Update" button. The new fields should now
mail me direct.
Have a nice day.
print
created
fields in
that
don't
> Thanks
That's exactly what i needed. Thanks. As far as the second part of
and the labels in Crystal. I can't seem to find the labels to change
> Definitions,
> new "Report Style".
> mail me direct.
> Have a nice day.
> print
> created
> fields in
> that
> don't
> > Thanks
