Crystal Report 8 and Vantage 4
Yes, we had some rather intricate formulas in our CRW 7 which when we tried them on CRW 8, failed. Seagate said it was because CRW 7 had a bug in it which would recognise an empty field instead of classing it as a "null" field. I would have had to re-write almost every report to fix this, and as I am already flat out, the project was shelved. We might look at it again when we look at Vantage 5.1
Our case may have been special, as the errors were mostly in having to re-calculate aging differently to the American system. You might have no trouble at all, depending on how complex your formulae are.
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
Phone: +61 8 8245 6789
Fax: +61 8 8245 6788
Direct Phone: +61 8 8245 6732
Postal Address: PO Box 1141, Marleston SA 5033
Site Address: 37 Belford Ave, Devon Pk SA 5008
email: dsloan@...
Web: http://www.entechgroup.net
----- Original Message -----
Sent: Tuesday, August 14, 2001 12:56 AM
Subject: [Vantage] Crystal Report 8 and Vantage 4
We are currently using Vantage 4 and Crystal Reports ver. 7 for
customized forms. Did anyone have problems with upgrading to Crystal
Report ver. 8 while using Vantage 4.0?
>snip<
We've had no problem with Crystal 8 on Vantage 4.0. If you distribute
reports/forms the distribution facility has to be downloaded and installed
seperately. Stay away from Crystal 8.5 which is flakey with Vantage (but
the patch does help) and especially if you distribute reports because you
can't at all with 8.5 (must use web services).
-Todd C.
Sent: Monday, August 13, 2001 10:27 AM
None. It went well.
Rick Gors
MR/MMIS
Osco
> Thanks,
> have already linked your email address to a yahoo id to enable access.
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
