Registry entry got it!
Create a String called Password and insert password.
I really should modify the XML to contain the data but I don't know how.
~Charlie
_____
Ross Hughes
Sent: Tuesday, February 03, 2009 10:54 AM
Subject: RE: [Vantage] Re: Crystal report asking for PW
You need to modify the local registries by adding keys for username and
password.
I don't have exact instructions with me but it can be found in Tech Tips on
the Epicor site.
Ross
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Lynn
Sent: Tuesday, February 03, 2009 9:49 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Re: Crystal report asking for PW
Sorry, I can't help you.
I added 4 tables to the Job Traveler Report Data Definitions. I did
not use ODBC.
Lynn
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
Wilson" <foamdesigncsw@...>
wrote:
Behalf Of
http://groups. <http://groups.yahoo.com/group/vantage/files/>
yahoo.com/group/vantage/files/.
http://groups. <http://groups.yahoo.com/group/vantage/messages>
http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo! Groups Links
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.10.16/1928 - Release Date: 1/31/2009
8:03 PM
~Charlie
_____
Ross Hughes
password.
the Epicor site.
Ross
Behalf Of
Lynn
not use ODBC.
Lynn
wrote:
>odbc.
> I have not changed the XML at all I'm linking the xml across to the
>the job
> Basically I had to pull in the Customer PO number that applies to
> and another customized field off the orderdtl table that holds infothat we
> keep for a specific customer.odbc it
> Now that I added the JobProd, OrderHed, and OrderDTl table via the
> is now asking me for the password to make the ODBC connection eachtime we
> attempt to print a job travler.[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> ~Charlie
> ________________________________________
Behalf Of
> Lynnname
> Sent: Tuesday, February 03, 2009 10:27 AM
> Charlie:
> I'm a little unclear. Are you using ODBC? Or are you modifying the
> Epicor-provided Data Definitions and Epicor-provided Crystal Report
> for the Job Traveler?
> If you are using the Epicor provided reports, note that the CR Job
> Traveler contains sub-reports. Is it possible when you Set your new
> Datasource in CR to your new xml, you forgot to press the Update
> button for the subreports?
> If you neglect to "Update" the subreports when you update the main
> report, you will get a message asking you to provide a database
> & password."Charlie Wilson" <foamdesigncsw@>
> Lynn
> wrote:Report.
> > All,
> > I have gone in and done some customization to the job trav.
> I had toget
> > link a couple tables from the DB into the XML data in order to
> the data------------------------------------
> > I was after. However now each time we run the Job Trav. It ask us
> for the DB
> > password. Is there a way that I can make it not ask for this
> password and
> > auto populate this info?
> > ~Charlie
8:03 PM
