Crystal Report Calculation Field Format
Both of these formula suggestions worked - thanks!
I am attempting to add barcoding to the PO Form (V8). The field I need
to barcode is the PO #. For example, with PO 402, I need to make
the "402" say *402* and then format with the DataWorks Bar 39 font.
The problem is that when I use one field in a calulation and try to add
*____* to it, It returns a value of *402.00* and I don't see anyway to
format or get rid of the .00
Any suggestions?
Thanks, John
Hi John,
Try the following in your formula
"*" + CStr({POHeader.PONum},"#") + "*"
Regards,
Stephen Edginton
Sent: 02 October 2006 13:39
Subject: [Vantage] Crystal Report Calculation Field Format
Any suggestions?
Thanks, John
I would use the formula:
"*"+ totext({POHeader.PONum},0,"")+"*"
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Hi John,
> Regards,
> Stephen Edginton
> From: JohnBob [mailto:jholden@...]
need
add
to
> Any suggestions?
> Thanks, John
