Crystal Report - Date Range
Hi Lauren,
Change your Select Expert formula to the following:
{OrderHed.OrderDate} in [{?DateRange}]
That should work.
Nigel.
--- In vantage@yahoogroups.com, "Lauren Hellings" <LaurenH@...> wrote:
> I have written a custom Crystal Report for tracking Order Booking
> changes in Vantage 8.03. I am attempting to create a Parameter
Field so
> users can run this report by Order Date Range. I get the prompt for
the
> Date Range, but the report ignores the dates entered into the
prompt and
> pulls every Order entered into Vantage since our Go Live. The only
way I
> can get the report to generate by date is to hard code it in
through the
> Select Expert.
> Has anyone encountered this issue before?
> Thank You,
> Lauren L. Hellings
> Systems Administrator
> Ericson Manufacturing Co.
> 4215 Hamann Parkway
> Willoughby, OH 44094
> P: (800) ERICSON x263
> F: (440) 951-1867
> LaurenH@...
> http://www.ericson.com/
> Confidentiality Notice: This email message, including any
attachments,
> is for the sole use of the intended recipient (s) and may contain
> confidential and privileged information. Any unauthorized review,
use,
> disclosure or distribution is prohibited. If you are not the
intended
> recipient, please contact the sender by email and delete all copies
of
> the original message
changes in Vantage 8.03. I am attempting to create a Parameter Field so
users can run this report by Order Date Range. I get the prompt for the
Date Range, but the report ignores the dates entered into the prompt and
pulls every Order entered into Vantage since our Go Live. The only way I
can get the report to generate by date is to hard code it in through the
Select Expert.
Thank You,
Lauren L. Hellings
4215 Hamann Parkway
F: (440) 951-1867
LaurenH@...
Confidentiality Notice: This email message, including any attachments,
confidential and privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient, please contact the sender by email and delete all copies of
