Crystal Report error when run from w/in Vantage
Yes, It is defined correctly in Vantage.
And, yes, I have re-updated the report several times thinking that was the issue.
I have tried to find an allocation field that I could use instead, but I can't find one.
So, I am back to trying to fix this.
----- Original Message -----
Sent: Thursday, July 10, 2008 8:05:52 AM (GMT-0800) America/Los_Angeles
Subject: [Vantage] Re: Crystal Report error when run from w/in Vantage
When you were in your report in Crystal and you opened the "Set
Datasource Location" menu option and used the "Replace With"
and "Update" commands, did you press the "Update" button for both
your Report-ReportDataSet and your SubReport-ReportDataSet.
If you have a subreport, in the upper half of the window under
Current Data Sources, the subreport will be listed separately below
the main report.
You have to highlight them each separately and press the Update
button for each one.
Lynn
--- In vantage@yahoogroups.com , Jennifer George <jgeorge@...> wrote:
> I little background... I took the Stock Status Report. Created a
new data definition and added the OrderDetail and the PartLot
tables. Modified the report to show the Expiration dates on the Lots
and then added a subreport that shows all the orders for said part
number.
> I can generate the data in Vantage and it runs great from Crystal.
> Problem is, when I choose that style from w/in Vantage and try to
preview it or print, I receive the following error.
> Error Detail
> Load report failed.
> Stack Trace
> at
CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDoc
umentIsOpened()
> at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load
(String filename, OpenReportMethod openMethod, Int16 parentJob)
(String filename, OpenReportMethod openMethod)
> at Epicor.Mfg.Lib.Report.EpiCrystalViewer.LoadReport(Object
state)
> Inner Exception
> Invalid field name.
> C:\DOCUME~1\jgeorge\LOCALS~1\Temp\StockStatusExpAll {60CDD8F5-9753-
40E9-9C59-2C206D4C69DC}.rpt
> Inner Stack Trace
> at
CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.O
pen(Object& DocumentPath, Int32 Options)
> at
CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open
> at
umentIsOpened()
> Anyone ever see this error? I don't understand the "Invalid field
name".
> I know it has something to do w/ the subreport. Do you think that
it doesn't like the variables that I'm passing back and forth?
> Any suggestions would be greatly appreciated.
> Thanks!
> jen
I little background... I took the Stock Status Report. Created a new data definition and added the OrderDetail and the PartLot tables. Modified the report to show the Expiration dates on the Lots and then added a subreport that shows all the orders for said part number.
Problem is, when I choose that style from w/in Vantage and try to preview it or print, I receive the following error.
Error Detail
Load report failed.
Stack Trace
at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDocumentIsOpened()
at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod, Int16 parentJob)
at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod)
at Epicor.Mfg.Lib.Report.EpiCrystalViewer.LoadReport(Object state)
Inner Exception
Invalid field name.
C:\DOCUME~1\jgeorge\LOCALS~1\Temp\StockStatusExpAll {60CDD8F5-9753-40E9-9C59-2C206D4C69DC}.rpt
Inner Stack Trace
at CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.Open(Object& DocumentPath, Int32 Options)
at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open(Object& DocumentPath, Int32 Options)
Anyone ever see this error? I don't understand the "Invalid field name".
I know it has something to do w/ the subreport. Do you think that it doesn't like the variables that I'm passing back and forth?
Thanks!
jen
Is the path to the crystal report correctly defined in vantage?
Kunal
To: vantage <vantage@yahoogroups.com>
Sent: Thursday, July 10, 2008 9:22:09 AM
Subject: [Vantage] Crystal Report error when run from w/in Vantage
I little background.. . I took the Stock Status Report. Created a new data definition and added the OrderDetail and the PartLot tables. Modified the report to show the Expiration dates on the Lots and then added a subreport that shows all the orders for said part number.
Error Detail
Load report failed.
Stack Trace
at CrystalDecisions. ReportAppServer. ReportClientDocu mentWrapper. EnsureDocumentIs Opened()
at CrystalDecisions. CrystalReports. Engine.ReportDoc ument.Load( String filename, OpenReportMethod openMethod, Int16 parentJob)
at CrystalDecisions. CrystalReports. Engine.ReportDoc ument.Load( String filename, OpenReportMethod openMethod)
at Epicor.Mfg.Lib. Report.EpiCrysta lViewer.LoadRepo rt(Object state)
Inner Exception
Invalid field name.
C:\DOCUME~1\ jgeorge\LOCALS~ 1\Temp\StockStat usExpAll {60CDD8F5-9753- 40E9-9C59- 2C206D4C69DC} .rpt
Inner Stack Trace
at CrystalDecisions. ReportAppServer. ClientDoc. ReportClientDocu mentClass. Open(Object& DocumentPath, Int32 Options)
at CrystalDecisions. ReportAppServer. ReportClientDocu mentWrapper. Open(Object& DocumentPath, Int32 Options)
Thanks!
jen
the main report.
Lynn
number.
> Error Detail
> Load report failed.
> Stack Trace
> at
umentIsOpened()
state)
> Inner Exception
> Invalid field name.
> Inner Stack Trace
> at
> at
> at
umentIsOpened()
name".
> Thanks!
> jen
