Crystal report Filtering Help please
yes i am creating a Bill of material, so the best way is to create
sub report ok will try that
thank you
--- In vantage@yahoogroups.com, "Dave Olender" <dolender@...> wrote:
> Ms. Kirsty: I'm assuming you are looking for a job BOM and NOT a
> MOM. If that's so, then I would recommend using subreports to list
> the operations and materials.
> Your main report would be based on the JobHead table (where you can
> get the project number) and then you would link the subreports to the
> main report via the JobNum.
> This can be done easily as an ODBC, however as a BAQReport it will be
> a little more difficult.
> Hope this helps,
> Dave Olender dolender@...
> PH:651-246-3281
> --- In vantage@yahoogroups.com, "kirsty2179" <dobby01@> wrote:
> > Trying to crete BOM need to filter so that i can obtain just the
> > details of the project number and it list of materials.
> > How can this be done in crystal report not very good at report,s any
> > help would be apprehised.
Hope this helps,
PH:651-246-3281
